I'm just gonna stand back and film the fireball...
PNW Chit Chat thread
So I should run my electric fan on the aux fan low speed temp (91c) but on the high speed circuit? (bypass the resistor)
I replaced the 91/99 degree switch with the 80/88 degree switch (61-31-8-361-787). I have the high speed hooked up to the 88, and the low speed is controlled by my A/C Button, either on or off... if I know it is going to get hot on the track or in traffic I can turn on the low speed before the car gets hot enough to trigger the 88 degree switch.Comment
Also, this way you have both a high speed and low speed.Comment
If I have any issues I may try the switch you linked. Thanks, I was going to just do a 2 prong but I want to keep all stock connectorsComment
I just don't see a point of cooling prior to the thermostat opening. 91c is only a few degrees higher than 88c. The fan is 2500 CFM should be enough to keep it cool
One thing I would recommend is testing your switch. I had pulled my stock one out and it wouldn't trigger at all, I had a butane torch sitting on it, and nothing haha.Comment
You will be fine with that setup for sure. Why not go down to the 88C thermostat? Or have you. Link me to your build thread! Haha.
Actually I do have a build thread, its this one! LOLComment
I have no build thread, I wasn't aware that M50 had something besides a 88 thermostat. As for the switch, radiator/switch is only a couple years old but no idea if the sensor works. I will just wire it in and see if it works while I bleed the system. If it doesnt work I will grab the 88 aux fan switchComment
