PNW Chit Chat thread
does anyone know a good way to get rid of rear camber w\o spending $1000+. I was on the freeway today doing 60. Dropped it into 3rd and I broke traction with my 245s... I took a look at the tread I have left and its probably only going to last me another 5-10k miles. I'm not trying to replace this much rubber this often.sigpicComment
or this
Shit, I have tons of activated carbon for fish tanks, will that actually work? I feel like it would just blow chunks of carbon out of my exhaust lol.
Sent from my iPhone using Tapatalksigpic
Currently without an e30. Will probably die soon.
24v guys, there is a spring loaded plug on the back side of the oil filter housing on my m50nv just above the oil pressure switch. With the motor off I can press this back in towards the housing. With the motor on it's a steady stream of oil that leaks out. What is this and how can I fix? Realoem makes it look like this is where the vanos hose would hook up...84 325e - 91 325i - 92 318 touring - 91 Trans Am - 01 S4 avant - 03 S-type R - 96 F350 - 15 SS - 84 Biturbo - 91 Defender
Our solid 12mm rear subframe riser bushings are designed to extend the life of your rear tires. These E30 subframe rise bushings are made with UHMW material.
does anyone know a good way to get rid of rear camber w\o spending $1000+. I was on the freeway today doing 60. Dropped it into 3rd and I broke traction with my 245s... I took a look at the tread I have left and its probably only going to last me another 5-10k miles. I'm not trying to replace this much rubber this often.Comment
sigpicComment
