PNW Chit Chat thread
  • HarukoE30
    • Nov 2011
    • 1057
    #3781
    Originally posted by LuckyHenriksen
    Oh, and if you are swapping Phil's M20i engine and using Eric's 5 speed setup it will be fine. The trans out of his vert parts car is already behind an 'i' motor, so it will fit behind an 'i' engine without issue. Make sure you get the harness and DME from Phil's car also. But I am sure you already knew that ;)
    So what you're saying is that both the parts I am shopping basically bolt up, I just need to get an 86e driveshaft to get her moving?
    edit: Yeah he said it was solid and came with everything I needed. So my only issue than is the drive shafts right? Because the 86e are shorter than the i models
    Originally posted by James Crivellone
    1) The internet is NOT serious business.
    • LuckyHenriksen
      • Jun 2010
      • 4244
      #3782
      Yes, doesn't matter the year of the vert, they all got 'i' motors. And as far as driveshafts any manual shaft should work
      Bahama Beige E23 Project
      Bluebird Bus Conversion
      New Oregon Trail
      • HarukoE30
        • Nov 2011
        • 1057
        #3783
        Omg this shit could work. Holy shit why did I think I was getting an 88 eta transmission haha. All I need for the 86e to work is the i model driveshaft, right Lucky?
        • LuckyHenriksen
          • Jun 2010
          • 4244
          #3784
          Yes sir
          New Oregon Trail
          • 5Toes
            • 9836
            #3785
            Grrrr
            The fuelinjector harness connector is stuck. So I got smart (well so I thought) and locked vice grips onto the bottom fat part and channellocks to the top. Well top cracked :( So I pull back the rubber cover and took off all the cracked plastic. It is still stuck
            So I might just wire each connector individually... http://www.spece30.com/forum/3-getti...jector-harness
            Would butt joints with heatshrinked insulation over each end be fine for this?
            • HarukoE30
              • Nov 2011
              • 1057
              #3786
              Yes sir
              Wow, time to send some PM's, call mom for the truck, U-haul for the trailer, and off to Roseburg, Oregon I go. I forgot I need a cherry picker & I may get me a new tool set for this :???:
              Edit: I need a Bentley for this swap as well. Time to hit up ebay & craigslist
              • e30austin
                • 15382
                #3787
                Sorry Haruko, I didn't know you were doing an "i" motor swap. I thought you were leaving the "e" motor in. Sorry for any confusion.
                • HarukoE30
                  • Nov 2011
                  • 1057
                  #3788
                  No no, I wasn't being clear enough at first, that's my fault. For some God awful reason I kept thinking the eta transmission was staying in the car & that a i motor/transmission wasn't going in. I'm trying to get the car for $300 and the owner keeps trying to tell me "it's a project car, it's a project car, it's a project car!"
                  :hitler: Like I fucking know that, but what he doesn't know is that I am swapping the engine and transmission out so it doesn't matter. Here's the ad for it for you guys, body is solid, interior is 6/10 tan color :down:, needs a new glove box, and passenger window fixed to be able to roll it down.
                  For $300 it isn't bad, I have seen worst and people were asking for more.
                  • LuckyHenriksen
                    • Jun 2010
                    • 4244
                    #3789
                    Way to go Austin ;)
                    Haruko, good luck with your project
                    New Oregon Trail
                    • LuckyHenriksen
                      • Jun 2010
                      • 4244
                      #3790
                      I see no ad
                      New Oregon Trail
                      • HarukoE30
                        • Nov 2011
                        • 1057
                        #3791
                        I see no ad
                        Check the craigslist section, roseburg for the city, than bmw, should be the one listed for $350
                        edit: link to the album
                        Upload, organize and share your photos with ImageShack. Fast, reliable image hosting with albums, privacy controls, direct links and resizing.
                        Side:
                        front:
                        • e30austin
                          • 15382
                          #3792
                          Way to go Austin ;)
                          • HarukoE30
                            • Nov 2011
                            • 1057
                            #3793
                            Hey, Lucky, not sure if I will but I may need to buy that pedal assembly off you. I'll let you know once I get the car here & I settle my brain down enough to think.
                            • LuckyHenriksen
                              • Jun 2010
                              • 4244
                              #3794
                              Yea man sounds good
                              New Oregon Trail
                              • DrJosh
                                • 2011
                                #3795
                                If anyone is interested I am waxing snowboards and skis for $10 flat. It is a hot wax and I use One Ball Jay only. I can apply any temp you'd like or I can pick for you based on current conditions. I can also clean up your edges if you need it for a bit more as well as deliver/pickup.
                                I do also offer private instruction for those looking to get into the sport. It is a much better deal then purchasing lessons at the hill, especially at Crystal (where I used to instruct). I general instruct at Snoqualmie due to terrain, ease of access, and price. But I am available to go else where such as Crystal, Stevens, and even Baker. I am also available mid week for Snoqualmie
                                Originally posted by Sonny
                                I am a meme for our community.
