PNW Chit Chat thread
  • Metallated
    • Dec 2016
    • 1074
    #38851
    Originally posted by Wschnitz
    BTW if you are looking for lock nuts for E30 dont buy those trash 'oem' ones that are the squiggly line type, the metal is too soft and they strip.
    Ask me how i know.
    Hahaha okay thanks for the advice, do you think these ones I linked earlier are worth getting?
    https://www.ecstuning.com/b-vms-raci..._ptBoCtHrw_wcB
    • BraveUlysses
      • Jun 2007
      • 3781
      #38852
      i would not recommend splined lugs, just get standard ones
      you will fuckin' hate life if you can't find the adapter
      • Matt-B
        The Waffler
        • 3856
        #38853
        hit up kaliboy, he makes good shit, i wont go anywhere else for wheel hardware.
        • Wschnitz
          • 8089
          #38854
          Splined ones are fine, I have them on my Suzuki. I just bought a couple more of the adapters.
          willschnitz
          • e30austin
            • 15382
            #38855
            Originally posted by DaWildBeast
            Is it possible that my cps is broken even though my car has spark and fuel? My old cps wire was cut by the timing belt so i bought a new cps but it is not anything like the oem one. When I try to start my car it turns over and sounds like it wants to start but doesn't. And whenever i pull out my spark plugs they smell like fuel
            Sent from my SM-G920V using Tapatalk
            Pull all the plugs, pull the fuel pump relay, crank it for 5-10 seconds, drop a little bit of oil down each cylinder, reinstall plugs and fuel pump relay, fire it.
            • DaWildBeast
              • Mar 2016
              • 244
              #38856
              Just use a syringe or what to put the oil down there? Like a teaspoon of oil or how much? Thanks for the tips
              • e30austin
                • 15382
                #38857
                You can use one of those piston style oil squirters. O'Reilly's sells them.
                • Matt-B
                  The Waffler
                  • 3856
                  #38858
                  ah yes, the pistol oiler
                  i like
                  • DaWildBeast
                    • Mar 2016
                    • 244
                    #38859
                    i like
                    Yup just bought it
                    • DaWildBeast
                      • Mar 2016
                      • 244
                      #38860
                      Okay so i did it 3 times and it started for 2 seconds then shut off. I didnt check the spark plug gap because i couldnt find a gapper but atleast it started
                      • Pdxseth
                        • May 2012
                        • 3124
                        #38861
                        Works every morning when Austin starts his cars.
                        Sent from my iPhone using Tapatalk Pro
                        • DaWildBeast
                          • Mar 2016
                          • 244
                          #38862
                          lmao it did make it start though.
                          • Pdxseth
                            • May 2012
                            • 3124
                            #38863
                            Is it possible you could have mixed up the cps and tps plugs?
                            • DaWildBeast
                              • Mar 2016
                              • 244
                              #38864
                              lol im 99 percent sure that i didnt even touch the tps plug. The timing belt sawed through the old cps sensor thats when it started being a retard engine. But i also replaced the plugs and didnt gap them but i dont think that would foul out the plugs every time i start it. Ill check that i didnt swap the cps and tps plug in tomorrow
                              • Matt-B
                                The Waffler
                                • 3856
                                #38865
                                okm to save you some headache.
                                essentially any bmw motor from 1999 and before will run with everything unplugged, except crank sensor.
                                i tested this theory on my s52 and m50. Granted they run like shit, but they run. The crank is basically the most important sensor, and interacts will all others
