PNW Chit Chat thread
    Happy birthday dude!
    I decided to hibernate all morning to avoid the cold.
    Originally posted by Sonny
    I am a meme for our community.
      Yes, my commute was pretty cold as well. I had to wear my robe when I went down to my office in the basement. It's rough out there..
      Thinking I am going to take Friday morning off and see if Skibowl gets some decent snow.
      1984 Alpina B6 2.8/1 #35
      1991 Racecar (Chase Schmidt's former drift car - M30)
      2006 BMW X3
        Hows the conditions down in Oregon? Cant seem to get any new snow in the mountains up here, just cold and dry..
        91 Alpinweiss2 318is OBD2 S52
          ^ supposed to snow tomorrow, wednesday, and thursday.
            Yea i saw that. not a huge amount but ill take it! I'm gonna be going up Thursday to Stevens.
              Got the car to run...but only for a few seconds. Fuck.
              Autobahn Motorsport - Restoration and Service - Portland, Oregon
              503.967.3800
              '72 2002 pickup | '88 M5 | '89 330is | '89 M3 | '01 Z3M | '11 328xi-t
                Some improvement is better than none
                Originally posted by bmwm42
                PNW vulture pm me for parts
                Strategic nw e30 command
                  What happened?
                  out dated sig is out dated
                    She lives. Finally.
                    So basically, I parked it for a few days. Went to go start it and it ran like total and complete shit. I said "fuck it" and parked it for a few hours, then I came back to the shop. Went to go start it and nothing happened. Brought it in the shop and changed the fuel pump fuse and relay. Nothing. Fuck. It was late and I was tired. Went home. Came back the next morning, changed the fuel pump, fuse and tried another newer relay. Nothing.
                    It was really cold out, so I put the battery on the charger overnight and went home. It was cranking really hard, almost like it had a weak battery, but not really. Hard to explain, but I did take a video with my phone. Came back today and pulled the plugs. Flooded. Sure as fuck isn't gonna run like that. Put the plugs in the parts washer for a few minutes. Popped 'em back in and it runs.
                    I think my whole problem was a shitty battery. Ugh.
                    503.967.3800
                      My car has been cranking really slow in the morning due to the coldness. It probably is just the battery dude.
                        She lives. Finally.
                        Woah woah woah... same problem as me I think. So if the plugs were "fouled" how did you remedy that? I just put new plugs in as of like August... dont want to buy more!
                        And also, how did you get the fuel out? just crank it with plugs out?
                          short answer: yes. Same method can be used if your motor is hydro locked, but only in an emergency would I use that method.
                          2006 BMW X3
                            First, make sure your battery connections are good (yes, overstated, but my dad seems to think that having shitty connections were my problem all along.)
                            The plugs were soaked with fuel and car sounded REALLY weak. I put the battery on the charger (while connected to the car) and yanked the plugs out and cranked it (not for long mind you, maybe five seconds at most.) I stuck the plugs in my parts washer and dried/wiped them off really well. Installed them and started right up. However, due to having all that fuel in the chamber while not firing, your oil will thin out and mix with fuel and the car will smoke like crazy. You will need to also do a full oil change.
                            Hope this gets your problem solved. Sounds very similar to my issue, so I wouldn't be surprised if we had the same issue!
                            503.967.3800
                              Also, yank the fuse to the fuel pump while cranking (obviously.)
                              503.967.3800
                                you and toes having something in common lol
