Need advice e30 m5x swap
  • tacollama13
    • Sep 2024
    • 10
    Originally posted by 82eye
    if you're gonna stick to an auto the swap is not worth the cost. it will actually cost more than a regular swap. you'll have zero choice but to swap in a matching trans, and then a possible custom driveshaft etc. there really is nothing for info on an engine swap retaining an auto trans that i've seen. you can search the forum, but i don't recall anyone bothering.
    rebuilding the original or swapping in a known good m20 are your very best options for the current driving goals you have for the car.
    I appreciate the info, in the case that I could find a donor auto 328i with both engine and trans, would you know how difficult the rest would be in regards to the rest of the drivetrain? As much as I want to try to do everything myself I'm not against sending something out for machining or getting something custom fabricated if need be.
    • 82eye
      • Jan 2009
      • 2067
      a quick look found this : https://www.r3vlimited.com/board/for...rmation-thread
      he doesn't seem all that active here but you may be able to reach out and find more from him. he's very occasionally on bfc some time as well.
      • moatilliatta
        • 6151
        TACO Served SPICY.
        Keep digging to where you want to be and you'll get there.
        @Zakspeed_US
        • 82eye
          • Jan 2009
          • 2067
          lol just noticed the op is already having issues with the one source i found for the info he wants
          • Panici
            • Dec 2009
            • 2500
            Originally posted by tacollama13
            Well sorry to disappoint but I am serious, I'm not planning on doing this swap for at least 10 months and I'm trying to learn as much as I can
            Glad to hear it.
            I think the point we're all trying to make is that an engine swap is a HARD job for a home / hobbyist mechanic.
            If you're going into this without prior wrenching experience it'll be very easy to get in over your head.
            Everyone starts somewhere, and if you're not planning on starting the swap for a while, this is a good time to refresh the other mechanical systems of the car.
            This will gain you valuable experience with tools and mechanical systems, and needs to be done anyways on an old car, to have a reliable ownership experience.
            • tacollama13
              • Sep 2024
              • 10
              Originally posted by Panici
              Glad to hear it.
              Thanks, I think ill try working on that this winter once I have access to my car. Thankfully I have a few buddies who work at shops who have offered to lend me assistance but none of them have any experience on BMWs let alone e30s so I'm trying to fill that gap with knowledge i can research and get by working hands on with the car.
              In my situation with my engine, would you recommend rebuilding or swapping in a new m20? I want to learn as much as I can but if one involves much less cost for the same learning I'll take it.
              • Panici
                • Dec 2009
                • 2500
                Swapping in a good used M20 will be the easier option.
                Try to get one with proof of compression numbers so you're not in the same boat again.
                Then you can put your old engine on a stand, and pull it apart (and possibly rebuild) as a further learning experience.
                • hasa
                  • May 2013
                  • 306
                  Follow this.
                  • tacollama13
                    • Sep 2024
                    • 10
                    this sounds like a great idea, thanks!
                    • moatilliatta
                      • 6151
                      For Sale: strong running m20b25 engine, ecu and engine harness. 175-180 cold compression numbers in as 6 cylinders. Located in Maryland. $1,000 for everything (motor, ecu, engine harness).
                      @Zakspeed_US
                      • TobyB
                        • 5268
                        Also I don't need people telling me im f#$%ed or should just do something completely different, if you're not gonna at least attempt to give me some info or help then just dont reply lmao
                        oh, honey, you're on R3v, not facefook...
                        your best bet, if you want to learn, is to start by finding a used M20, and just doing a 1:1 engine change.
                        If that seems fun and easy (after it's done, of course) THEN maybe start looking for an M54B30.​
                        and to read what people post...
                        t
                        • tacollama13
                          • Sep 2024
                          • 10
                          t
                          nice man thanks for the input
