Markert Motor Works Dyno Thread (many inside)
  • taft125
    • Apr 2015
    • 8
    #226
    Okay, I PM'd you. Hit me back when you can and we'll schedule something. I want this data to get out there.
    • 328ijunkie
      • May 2007
      • 3961
      #227
      Dyno Tuned a Forum Members M50man/S52 Cam M52 E30 Today. Stock headers and a ehhh exhaust setup. :)
      Car Previously had a DesertBMW tune for said mods. The Hackentt/DesertBMW Tune is basically a off the shelf shark injected S52 tune, even though its running a 2.8. Fuel trims and load was off everwhere but luckily the ecu is smart so it still made decent power even with massive knock correction... Ill leave it at that.
      Before on DesertBMW tune and after reflashing with our off the shelf and retuning from there.
      Before log:
      Check Us out on Facebook
      Full Product Line Tuning
      • 328ijunkie
        • May 2007
        • 3961
        #228
        Tuned the wifes car. Not really happy with the top end. didnt have time to figure out the cause. Spark blowout maybe.
        FBO 335i Pump gas only, stock 140k turbos. 6AT
        • 2mAn
          Señior Mod
          • 20989
          #229
          Can you do 335D tunes also? My friend would lvoe to tune his wifes daily when shes not paying attention :rofl:
          Simon
          Current Cars:
          -1966 Blue Boat
          -1969 Red VW
          -1986 White BMW
          -2006 Green Thing
          Make R3V Great Again -2020
          • 328ijunkie
            • May 2007
            • 3961
            #230
            Sadly not yet. Very limited market is the big problem with the D stuff.
            • taft125
              • Apr 2015
              • 8
              #231
              So, just want to go on record saying that taking my car to be tuned by Dave was a great decision. Everything is better, torque delivery is smoother and significantly more powerful, the idle is more consistent and steady, driveability has become so much better especially during part throttle situations which is basically 99% of the time. If you haven't tuned your car, hell even if you have, take it to Dave and the guys at Markert Motorworks to be dialed in. Great people, great experience and even better results. Leaps and bounds better than hakentt/desertBMW "tuning". I'll be going back through for more work in the future.
              • David325is
                • 194
                #232
                I want to see the chart for the other 335i ;)
                • 328ijunkie
                  • May 2007
                  • 3961
                  #233
                  Stock turbos still :)
                  • digger
                    • Nov 2005
                    • 6191
                    #234
                    might as well lower the redline to 6200rpm on that
                    • 328ijunkie
                      • May 2007
                      • 3961
                      #235
                      Still has 400whp at redline ;).
                      • The Dark Side of Will
                        • Jun 2010
                        • 2796
                        #236
                        M30's make peak power at 5200 ;-)
                          • Jun 2010
                          • 2796
                          #237
                          Yeah, but the ideal shift points appear to be in the 5800-6200 range.
                          • ForcedFirebird
                            • Feb 2007
                            • 8300
                            #238
                            Not sure what an m30 has to do with anything in this thread, but as far as the power drop, it looks to me like each gear will be at or near MBT, which is a good thing. (edit: assuming a 6k or so shift)
                            john@m20guru.com
                            Links:
                            • ForcedFirebird
                              • Feb 2007
                              • 8300
                              #239
                              Lol to overlapping posts
                              john@m20guru.com
                              Links:
                              • digger
                                • Nov 2005
                                • 6191
                                #240
                                yeah it also makes 400whp at 3600rpm, running it to high rpm just hurts parts and you'd end up going slower in this case
