Markert Motor Works Dyno Thread (many inside)
  • ncsubowen
    • Nov 2013
    • 1012
    #271
    Originally posted by 328ijunkie
    Give us a shout to discuss if you want (6788096531 or tuning@mmw.repair). We have a few different ways of doing things. Send in your ECU, we send you one already flashed, or we send you a remote tuning cable and remote flash the DME. Also the dyno isnt necessary for most applications but always cool to see what the car is putting down before/after.
    Will do. Have some work to do and supposedly the ECU comes preloaded with an E30 tune from the seller, so it should be enough to get me up and sorted out.
    4 doors.. so much room for activities!
    IG @bluebombr
    Transaction Feedback:
    http://www.r3vlimited.com/board/showthread.php?t=323622
    • 328ijunkie
      • May 2007
      • 3961
      #272
      3/10/16
      Tuned a E36 Track car today. S52 with Stock MAF, 24lb injectors, ebay headers, meh exhaust setup, M50 manifold, hot air intake and had a reputable tuners custom dyno tune on it. Not sure why he thought 11.5:1 AFR was brillant nor the ~5600RPM vanos shutoff point but whatever.
      Brought the AFRs back into a proper location and pulled back vanos shutoff point among other things.
      Check Us out on Facebook
      Full Product Line Tuning
      • ForcedFirebird
        • Feb 2007
        • 8300
        #273
        3/10/16
        Strange. I usually double up on wide bands during dyno tuning. Dyno in the tailpipe and up close.
        john@m20guru.com
        Links:
        • 328ijunkie
          • May 2007
          • 3961
          #274
          Yeah :dunno
          • 328ijunkie
            • May 2007
            • 3961
            #275
            3/30/16
            Tuned another E90 M3, 100% stock, Stock tune with testpipes and intake, and fully tuned with testpipes and intake.
              • 34835
              #276
              did you figure out any of that torque stuff?
              • 328ijunkie
                • May 2007
                • 3961
                #277
                Some, there's more on the table.
                • The Dark Side of Will
                  • Jun 2010
                  • 2796
                  #278
                  35 fricking HP's from off road pipes and a CAI? WTF?
                    • 34835
                    #279
                    probably the test pipe - no cats I'm guessing. S65 wants to breathe. :)
                    • 328ijunkie
                      • May 2007
                      • 3961
                      #280
                      I was surprised as well
                      Baseline and after mods baseline were 6 months apart too.
                      • JGood
                        • Jan 2004
                        • 7959
                        #281
                        That baseline is also weak for an s65. From what I've seen, they're typically 335-350 whp on a dynojet.
                        e30 restoration and V8 swap
                        24 Hours of Lemons e30 build
                        • 328ijunkie
                          • May 2007
                          • 3961
                          #282
                          Ive seen 310-345 stock on our dyno from them. Theyre just like S54s in that sense, some are much healthier than others.
                          • spiDmang
                            • 3941
                            #283
                            Dave, I'll be coming to you once I get my E46 M3 dialed in a bit more....Would love to get a tune on it once I get some decent headers slapped on her :)
                            91' 318iS - S54/6MT Swapped
                            08' E90 M3 6MT - Daily
                            Originally posted by IronJoe
                            Originally posted by 2mAn
                            • JGood
                              • Jan 2004
                              • 7959
                              #284
                              Interesting. You'd think with today's precision manufacturing processes, there wouldn't be that much of a variance anymore. That's a 10% difference...
                              • ForcedFirebird
                                • Feb 2007
                                • 8300
                                #285
                                Not uncommon at all, specially when you get into higher HP/L. Also, these engines aren't that "new" anymore, the s54 is what 17yrs old already, with the youngest ones at 8yrs or so? They might be a bit closer if they were all tested at low mileage.
                                john@m20guru.com
                                Links:
