Markert Motor Works Dyno Thread (many inside)
  • 328ijunkie
    • May 2007
    • 3961
    #241
    Lol. tough crowd around here. Just was trying to prove a point. The power band is less than ideal in many respects and a certain shift point would be ideal under many circumstances. This car sees track too.
    Check Us out on Facebook
    Full Product Line Tuning
    • 328ijunkie
      • May 2007
      • 3961
      #242
      12/7/15
      Retuned a car GTS car i had already tuned as OBD1 after converting it to OBD2, no other changes. S50, 3.5" MAF, 24lb, Ebay Headers, BW race exhaust.
      Retuned a OBD2 S50 swapped E30 M3 that had a TRM off the shelf flash on it. Has some weird aggressive cams in it that were doing some crazy stuff. Didnt make any power though?
      • 328ijunkie
        • May 2007
        • 3961
        #243
        12/8/15
        Tuned 2 E46 M's.
        First bone stock:
        Second 214k, stock intake with aftermarket headers/full exhaust
        Progression!
        • 328ijunkie
          • May 2007
          • 3961
          #244
          Tuned a GTS racecar today. Fresh S52 Build, M50 manifold, Headers, Stock cams with timing tweaks, BW race exhaust. 3.5" MAF had to get slapped on at dyno as stock MAF maxed out at ~6500... Stock Injectors. Was running M52 stock tune when it first came in.
          • spiDmang
            • 3941
            #245
            nice S52 #'s Dave ^^^
            i gotta get you guys to remotely flash my ECU once i convert to a M50 manifold :up:
            91' 318iS - S54/6MT Swapped
            08' E90 M3 6MT - Daily
            Originally posted by IronJoe
            Originally posted by 2mAn
            • 328ijunkie
              • May 2007
              • 3961
              #246
              Look forward to it :)
              • 328ijunkie
                • May 2007
                • 3961
                #247
                Few Notable Updates. Retuned an earlier E46 M3 after adding headers
                Pre/Post headers, no tuning changes
                After Retuning
                Progression: Stock Tune, Tuned, Then Tuned with headers
                Also retuned an Alum block M52 E30 after it got headers/a nicer exhaust setup
                • Chapel
                  • 633
                  #248
                  I have to say, I'm VERY impressed with the thoroughness of this tuning.
                  I think you'll have gotten a client out of me for sure.
                  BattleWagon|1996 GT Vertigo
                  • 328ijunkie
                    • May 2007
                    • 3961
                    #249
                    Thanks! Look forward to working with you. We try to pride ourselves on transparency and backing our work with data vs most of the competition :)
                    • Chapel
                      • 633
                      #250
                      hey look, I'm back on r3v again! :P
                      • 328ijunkie
                        • May 2007
                        • 3961
                        #251
                        1/4/16
                        Retuned a Schrick cammed, M50 manifold, shorty header, AA track pipe, HPDE car. Had 3.5" MAF/24lb injector, Schrick conforti tune on it already as the baseline.
                        Also fun fact of the day, changed on the dyno from a 3.5" MAF reducer and the stock ASC intake boot (with ASC still in place) to a silicone 3.5" to 3" smooth intake boot. No tuning changes...
                        • 2mAn
                          SeƱior Mod
                          • 20860
                          #252
                          Thats pretty significant! Im not sure what the ASC boot is, but Im guessing its the original rubber one.
                          Simon
                          Current Cars:
                          -1966 Lotus Elan
                          -1986 German Car
                          -2006 Volkswagen Jetta TDI
                          Make R3V Great Again -2020
                          • The Dark Side of Will
                            • Jun 2010
                            • 2796
                            #253
                            https://lh3.googleusercontent.com/-g...ost%2Bboot.jpg
                            Are you saying that the aftermarket part lost 4 HP on the top end?
                            Interesting.
                            • TheAxiom
                              • Sep 2015
                              • 59
                              #254
                              No, it gained power.
                              E92 Msport
                              • Chapel
                                • 633
                                #255
                                ASC is the traction control throttle body system
                                basically there's a SECOND throttle body in front of the main throttle body and the intake boot that goes from the MAF to the ASC Throttle is shorter.
                                Deleting the ASC throttle body requires a new intake boot.
                                I'm half tempted to do the ASC delete myself... I have an LSD and snow tires after all.
