Markert Motor Works Dyno Thread (many inside)
    • 34839
    #286
    Originally posted by JGood
    Interesting. You'd think with today's precision manufacturing processes, there wouldn't be that much of a variance anymore. That's a 10% difference...
    BMW dyno's every car that leaves their production line - they reject the ones that are lower than spec, but some of them end up coming out higher. I bet ones that are significantly stronger stock are fairly rare though.
    weren't S54s hand built?
    • digger
      • Nov 2005
      • 6119
      #287
      there aren't strong outliers, there are normal ones proabbly fit within a normal distribution of sorts, but there are weak ones which simply have issues with one of the many complex systems. alot can happen in a few years
      • JGood
        • Jan 2004
        • 7959
        #288
        Originally posted by ForcedFirebird
        Not uncommon at all, specially when you get into higher HP/L. Also, these engines aren't that "new" anymore, the s54 is what 17yrs old already, with the youngest ones at 8yrs or so? They might be a bit closer if they were all tested at low mileage.
        I was talking about the s65 dyno. But, yeah, points taken.
        e30 restoration and V8 swap
        24 Hours of Lemons e30 build
        • 328ijunkie
          • May 2007
          • 3961
          #289
          Few good updates
          4/19/16
          Tuned a schrick cam S52 track car. Has 3.5" MAF and 24lb injectors. Headers to stock midpipe. Running OBD1. Unnamed tuners off the shelf chip vs MMW dyno tuning :P
          Tuned a Turbo M50 E30 We OBD2 converted. running HX35 15psi tapering to 12 off WG spring, 140MLS 93oct. S50 cams
          Tuned another S54 E36. Stock plenum, ZM3 airbox, CPI headers, nice dual all the way back exhaust
          Check Us out on Facebook
          Full Product Line Tuning
          • The Dark Side of Will
            • Jun 2010
            • 2796
            #290
            Originally posted by 328ijunkie
            Few good updates
            4/19/16
            Is the stock midpipe (assuming E36) really that restrictive?
            I've heard of cam + header + supporting mods S52's hitting 280 to the wheels.
            • 328ijunkie
              • May 2007
              • 3961
              #291
              Obd2 midpipes aren't too bad. OBD1 ones are shit.
              • 2mAn
                Señior Mod
                • 20721
                #292
                What makes you say that? Any pics to compare?
                also, What cams does that car have?
                Simon
                Current Cars:
                -1966 Lotus Elan
                -1986 German Car
                -2006 Volkswagen Jetta TDI
                Make R3V Great Again -2020
                • Bimmerman325i
                  • 6854
                  #293
                  Note the necking down from 2-1-2 on the OBD1 pipe. That area chokes down to a very small diameter with a thick wall.
                  2017 Chevrolet SS, 6MT
                  95 M3/2/5 (S54 and Mk60 DSC, CARB legal, Build Thread)
                  98 M3/4/5 (stock)
                  • 328ijunkie
                    • May 2007
                    • 3961
                    #294
                    Schrick street
                    Your pic is dead
                    • 2mAn
                      Señior Mod
                      • 20721
                      #295
                      Thanks for the pic and the answers. Im getting my game plan ready for a full exhaust system, and what I see is that the separate piping going into the cat makes a big difference.
                      Simon
                      Current Cars:
                      -1966 Lotus Elan
                      -1986 German Car
                      • Bimmerman325i
                        • 6854
                        #296
                        Your pic is dead
                        Weird, I don't see a dead image.
                        98 M3/4/5 (stock)
                        • digger
                          • Nov 2005
                          • 6119
                          #297
                          Look at the different location of the merge/crossover....IMO that's more important than pipe size. Then They split it again 8" later wtf its just a weird x-pipe in effect
                          A short length of small piping isnt as restrictive as people think
                            • Jun 2010
                            • 2796
                            #298
                            The location of the secondary merge appears to have a BIG effect on S54 power output.
                            • digger
                              • Nov 2005
                              • 6119
                              #299
                              The location of the secondary merge appears to have a BIG effect on all inline6 power output.
                              fixed
                              • 328ijunkie
                                • May 2007
                                • 3961
                                #300
                                4/27/16
                                E46 M3 VF SC 6psi IC kit. VF Tuned vs Our retune. VF apparently doesnt see the need to alter factory vanos maps as well as overfueling like hell. Also BOV or something is freaking out up top. Boost falls off at ~7500.
