Markert Motor Works Dyno Thread (many inside)
  • M-technik-3
    • 18946
    #91
    What exhaust was that Ti running?
    • 328ijunkie
      • May 2007
      • 3961
      #92
      AFAIK, Ebay headers and a nice 2-1 merge (2.75) and vibrant mufflers... wasnt terribly loud
      Check Us out on Facebook
      Full Product Line Tuning
      • M-technik-3
        • 18946
        #93
        Ah using a S52 manifolds and OBD II mid section and getting a E30 Stromung mated to it. Hoping it's not too obnoxious.
        After it's done i might give you a line a flash tune for the car. runs much like you just posted .
        • digger
          • Nov 2005
          • 6145
          #94
          Originally posted by 328ijunkie
          Update 4/7/15
          No tuning here, just a dyno to dyno comparison... Car is an M52 318ti, M50 manifold, S52 Cams, Headers, Exhaust, 3.5" MAF, BBTB
          A shops dyno in atlanta with their tune on it:
          Same car same tune on the dyno we use (Switched run to SAE because the other shops dyno is run on SAE):
          STD Run:
          thats a different model dyno? land and sea?
          i went through data for 9 other "stock" E46M3 dynos on a DJ getting rid of the outliers that read quite low and high
          for each separate data point i used the maximum number as some had 3 curves run in succession etc
          TQ RANGE 227-242wtq AVE: 234whp
          HP RANGE 276-283whp AVE: 279whp
          yours was 233/276 when reduced by ~2% to estimate SAE.
          gotta hand it to dynojet they are pretty consistent when each of these dynos is a different physical machine scattered around a large continent.
          where as locally on a dyno dynamics shootout ive seen 180rwkw vs 210rwkw you get a bif difference between different shops
            • 34839
            #95
            yeah, people hate on dynojets for "reading high" (whatever that means) but they're very consistent and you can't really fudge the numbers.
            • 328ijunkie
              • May 2007
              • 3961
              #96
              Another bone stock E46M3 272STD=~268SAE
              • DesertBMW
                • Aug 2011
                • 1036
                #97
                Advertised was 333hp at the flywheel, this means there is a massive drop in horsepower trough the drivetrain (61 hp drop)
                • ForcedFirebird
                  • Feb 2007
                  • 8300
                  #98
                  A little on the high side for parasitic loss at ~18%. Typically if you multiply the WHP by .82-.85 (15-18%), you have an idea. 333 x .82 = 276. Yes, 61hp seems like a lot, but when you make more power, you tend to lose more at the wheels.
                  Non-rebuilt Spec e30's do about 150whp (~10% loss over advertised), but e30's less rotating mass with the brakes, hubs, less gears in the transmission, smaller differential gears etc etc.
                  Keep in mind catalyst, big mufflers, A/C, P/S etc also cause losses.
                  EDIT: Customer in line before me at the last dyno session had an e46m3 with Alpha-N and carbon air box made 280whp.
                  john@m20guru.com
                  Links:
                  • 328ijunkie
                    • May 2007
                    • 3961
                    #99
                    I was using that as somewhat of an example of this dyno reading ~3-4% low. :P
                    That is normal numbers (on our dyno) for a good E46M3 (stock)
                    • DesertBMW
                      • Aug 2011
                      • 1036
                      #100
                      With all the hype and the price of S54, I am not impressed at all.
                        • 34839
                        #101
                        that's fine. They will make 320+ with a tune and light mods.
                        • ForcedFirebird
                          • Feb 2007
                          • 8300
                          #102
                          Epic's race car was making 380+ with cams, air box and his tuning.
                          john@m20guru.com
                          Links:
                          • 328ijunkie
                            • May 2007
                            • 3961
                            #103
                            Highest stockish one weve seen was a bottom up stock rebuild with headers on stock US tune did 295 (shown on first post), tuned to 317whp on stock airbox/cams. Most M50 manifold S52s dyno around 230-235 on our dyno, with nice ass headers and a more agressive tune ive done ~255whp on stock cams S52, so youre getting ~60whp for 4-5k+ not to mention the powerband increase.
                            • 328ijunkie
                              • May 2007
                              • 3961
                              #104
                              best stock cam S52 vs best stock cam/airbox s54
                              • digger
                                • Nov 2005
                                • 6145
                                #105
                                sadly its all been downhill since the S54
