The comprehensive DOHC engine swap thread.
This is a sticky topic.
  • Jand3rson
    • 37587
    #1141
    Originally posted by highoutput
    If your using all the M20 stuff, cant you use whatever TO Bearing was used with the M20 set up as well??
    I'm piecing all this together right now as well.......
    Yes. I used a 325i flywheel, clutch kit, pilot bearing, throwout bearing, and Getrag 260.
    • dude8383
      • Jan 2005
      • 10387
      #1142
      Originally posted by Matt-B
      its also been covered 50 times a "EURO" 323i TO bearing, is the same as a 325i
      hate to call ya out on it but they're different. i can't for the life of me find the pic of the two sitting next to each other but the 323i TOB is taller than the 325i one.
      i think i might have both at my friends place and could snap a pic for comparison's sake.
      • bimmerteck
        • 762
        #1143
        Odd, the part numbers do not support your conclusion sir. ;)
        Part 21517521471 (CLUTCH RELEASE BEARING) was found on the following E30 vehicles:
        E30 323i Coupe, M20, Europe, MANUAL (1171) : Clutch
        E30 323i Coupe, M20, Europe, RHD, MANUAL (1172) : Clutch
        E30 323i Sedan, M20, Europe, MANUAL (1471) : Clutch
        E30 323i Sedan, M20, Europe, RHD, MANUAL (1472) : Clutch
        E30 325i Coupe, M20, USA, MANUAL (1113) : Clutch
        E30 325i Sedan, M20, USA, MANUAL (1413) : Clutch
        E30 325i Convertible, M20, USA, MANUAL (BB13) : Clutch
        • dude8383
          • Jan 2005
          • 10387
          #1144
          I'll grab part numbers for ya later tonight as well as pics for comparison. I had both of them sitting side by side when I did my 323i flywheel conversion on my m42 and they are different.
          The 323i tob was aluminum while the 325i tob has some plastic here and there.
          • dude8383
            • Jan 2005
            • 10387
            #1145
            http://www.realoem.com/bmw/showparts...21&fg=05&hl=60
            That part number is from an e21 323i equipped with an M20.
            • bimmerteck
              • 762
              #1146
              That PN comes back to euro e30s with pre 03/84 production dates as well as several other chassis, a good example of why PNs should be used when specifying a particular part. ;)
              03 CLUTCH RELEASE BEARING 03/1984 21511204525 $113.18
              03 CLUTCH RELEASE BEARING 21517521471 $75.34
              • dude8383
                • Jan 2005
                • 10387
                #1147
                http://www.m42club.com/forums/showpo...5&postcount=22 ;)
                It was a mix-up on my part because thats the TOB I needed to use when converting the flywheel to a single mass on my M42.
                You can go and pat yourself on the back now buddy.
                • Matt-B
                  The Waffler
                  • 3856
                  #1148
                  • mohamadr89
                    • 282
                    #1149
                    Originally posted by Ryan Stewart
                    Aaron my understanding is the master cylinder doesnt HAVE to be changed its just a nice upgrade while you are in there. The booster only has to be changed to make room for the rather large plenum.
                    i heard you can use the stock booster as long as you move it over to the right just a bit...
                    mtech 2 325ic
                    http://www.r3vlimited.com/board/pict...pictureid=7968
                    check out my donut vid
                    http://www.youtube.com/watch?v=Tw0paUP1FEQ
                    • mohamadr89
                      • 282
                      #1150
                      i have a 1988 e30 325ic, i also have a wrecked 95 m3 that im using the motor out of. the parts i know i need to buy are:
                      e34 525i oil pan, dipstick tube, dipstick, oil pich up tube.
                      e34 throttle cable
                      e36 engine mount arms
                      e28 535i or m5 engine mounts.
                      ix booster
                      since my m3 came with the original 413 grey lable i need to buy a 413 red lable.
                      i was told i can use my stock booster if i move it over a bit, is this true?
                      also can i use my 95 m3 driveline and diff? if so what will i benefit? thanks!
                      -moe
                      mtech 2 325ic
                      • A_Whelan
                        • Jul 2010
                        • 691
                        #1151
                        Quick question, how often should the timing chained be replaced?
                        r3vlimited Lanyard Group Buy!!!
                        • highoutput
                          • Apr 2011
                          • 94
                          #1152
                          e34 throttle cable
                          ix booster
                          -moe
                          I use my stock booster, but if i had to do it over again I'd get the new one that fits correctly. I slotted the holes in the firewall, and moved it over, but then I still had to shave the fins on the intake manifold a little. It worked in the end though.
                          24V M50, M3 cams, Turner Tune, full exhaust, ect....
                          • Matt-B
                            The Waffler
                            • 3856
                            #1153
                            every, 500,000 mi?
                            I think you should more check and replace as needed, tensioner, sprockets, and guides, never heard of a chain breaking
                              • 34830
                              #1154
                              they don't often break but they definitely stretch. a 500,000 mile chain would likely have the consistency of an overcooked noodle.
                              • mohamadr89
                                • 282
                                #1155
                                im so mad because i called the wrecking yard and they want about $900 for...
                                the throttle cable, oil pick up tube, dip stick, motor mounts, oil pan, ix booster, 413 red lable dmw, intake boot and maf sensor. i know its a lot of stuff for a good price but i still wasnt expecting to pay all this!!
                                mtech 2 325ic
