S54 swap questions and concerns
  • cek
    • Jan 2014
    • 85
    #211
    Originally posted by gpeterson
    Last two pictures & text at http://www.r3vlimited.com/board/show...1&postcount=15 describe how you can use the aux fan controller. I'd definitely recommend it, PWM fan is much nicer than something that cycles off & on.
    Any idea if the E28 fan will work with a PWM controller?
    Vlad: '87 535isMaytag: '87 528e'88 911Project Minerva - S54 E28
    • gpeterson
      • Aug 2012
      • 119
      #212
      Most likely would. Only potential issue I can see is the fan drawing more current than the controller can handle.
      • jink0619
        • 808
        #213
        Don't forget the o2 sensors(post cat) if that wasn't coverd yet
        E30love
          • 34839
          #214
          you don't need the post cat O2 sensors at all.
          • jink0619
            • 808
            #215
            Oops pre cat and fuel pump relay(black)
            E30love
              • 34839
              #216
              fuel pump relay = EKP. :p
              • jink0619
                • 808
                #217
                Ha! this reminds me of the time after my swap, car would not turn over, cause I mistakingly thought the Windshield washer relay was the EKP module DOH!
                E30love
                • 328ijunkie
                  • May 2007
                  • 3961
                  #218
                  Still need to stop by :)
                  Check Us out on Facebook
                  Full Product Line Tuning
