E30 M54 Swap Guide
This is a sticky topic.
  • vitiokas95
    • Dec 2013
    • 482
    #46
    very nice. Thanks for write up. I am sure as soon as my s50 die on me, I will do M54 swap for my race car. And I can use lots of parts from S50 swap I currently have.
    1990 e30 325is S50 swap (NASA GTS2 race car)
    1990 e30 325is
    1988 e30 M3 S50 euro swap
    • BMWerke
      • 893
      #47
      I built an m54b30 and put it I my e30 last just June. Almost a year later and i have 8k on the motor. I'm running it completely obd1 and with a g260. You have a cool car man, props.
      '90 325is DD, 5 spd swap-H&R springs-Euro Headlight Fully Built OBD1 M54b30. Ox Blood interior, 3.46 LSD with Z3M Diff Cover. Custom shifter, every bushing replaced.
      '86 325e- Donor car for swap/parts car
      '00 323i- BBS 197s Totalted
      '89 740 turbo Volvo- Donated
      • Navymr
        • Apr 2015
        • 35
        #48
        So all obd1? Such as m50 manifold and mech throttle single vanos? 413 dme? What do you think about no Disa? What are your build specs. See I planned to go obd1 but peer pressure convinced me of stock controller. What are your thoughts?
          • 34847
          #49
          it made sense before the stock DME was viable. Now, it would realistically be more work to convert it to OBDI, which is an inferior solution.
          • Navymr
            • Apr 2015
            • 35
            #50
            Then it's final that's the route I'll go. Anyone have a height measurement of the green m5 motor mounts? I plan on machining my own out of delrin but need a base height to start with
            • Navymr
              • Apr 2015
              • 35
              #51
              So I've been tossing an idea back and forth in my head. I've been into 4 m54 engines recently acquiring my parts for the swap. One part I guess I have to buy new no matter what is the coolant tubes that run down the block. One is heater inlet one comes from front cover. I know a vender has a solution to the front cover by pounding in an aluminum pipe. But what about the other? Anyone try tapping the hole with 3/4 npt or welding a 90 hose barb in there? Reason I ask about going this route is normally I wouldn't be too concerned with BMW's plastic tubes except the 4 sets I tried to harvest off other engine just disintegrated at the connection point. Anyways input appreciated. Thanks
              • Jordan
                • 12916
                #52
                Buy the plastic coolant pipes new. They aren't that expensive and last 12-15 years.
                https://mtechniqueabs.com/
                • Rocla
                  • 922
                  #53
                  Any ideas for building cruise control for m54 swapped car?
                  Current:
                  BMW 320i 2d 2.0 m20 -88
                  BMW 325i Cabriolet 2.5 m50 -88
                  BMW 316i touring 1.6 m40 -90
                  BMW 320i 4d 2,2 m54 -01
                  • stonea
                    • 2892
                    #54
                    Does anyone else know what other brake boosters will work, I've heard the 944 one kind of sucks
                    My Garage
                    Feedback
                    Instagram: Stone.Hopkins
                    • bmwmaster81
                      • Sep 2012
                      • 49
                      #55
                      I have heard that a e90 break booster should be fine.
                      • Navymr
                        • Apr 2015
                        • 35
                        #56
                        E90 booster works in e30? What's involved In fitament?
                        • steel330i
                          • 164
                          #57
                          2005 330i ZHP donor car...
                          So if I have the ability to get an '05 330i 6MT ZHP, should I be able to utilize the majority of the bits needed from the donor car or would I still need to fab as much as you have into my 1991 318i? TIA.
                          • stonea
                            • 2892
                            #58
                            You'd still have to fab everything that he had to. If there was an OEM solution Jordan would have used it.
                            My Garage
                            Feedback
                            • bmwmaster81
                              • Sep 2012
                              • 49
                              #59
                              Im doing the m54 swap right now and bought the same engine mounts from 6 series bmw.
                              But there is no thread to the end of the stud which i trimed and schould be bolted to the frame.
                              I think there is about 0.5 inch of the stud without thread
                              Did you use so much washers to bolt it down?
                              • Jordan
                                • 12916
                                #60
                                I didn't use any washers no. You may have to run a die over then to lengthen the threads?
