iX wheel thread
  • 6A LDY
    • Jul 2014
    • 318
    #151
    Originally posted by nando
    spacers make the offset lower, so no, you don't need spacers. ET25 is already a bit on the low side, but they should fit just fine with stock suspension and 205/55 tires.
    Oh thanks for clearing that up. It would be pretty tight with the hr and bilstein setup then
    1988 325iX - sold but not forgotten
    1984 MTech1 323i
      • 34847
      #152
      yeah it would rub over dips/bumps and with people in the back, not terribly but it could be annoying after a while. you could trim the rear flares and roll the fenders and it would fit fine.
      • 6A LDY
        • Jul 2014
        • 318
        #153
        Yeah that's what I figured.
        Like a good neighbor nando is there!
        1984 MTech1 323i
        • ludovic
          • Oct 2014
          • 20
          #154
          no, ET28 is too low for an 8" wheel/225 tire. you could maybe run a 205, but I'm thinking that would probably rub in the back anyway.
          Thanks Nando, 16x7 all around it is, then !
          • Bosco
            • Jul 2014
            • 3
            #155
            15x8 ET25 73.1CB stock suspension, How tight would they be and would spacers help?
              • 34847
              #156
              Too low for an 8. No, spacers push the wheels out more.
              • AWDBOB
                hooptie connoisseur
                • Aug 2013
                • 4516
                #157
                15x8 +36
                205/55 Direzza
                • 6A LDY
                  • Jul 2014
                  • 318
                  #158
                  what rims are those bob?
                  1984 MTech1 323i
                  • AWDBOB
                    hooptie connoisseur
                    • Aug 2013
                    • 4516
                    #159
                    Dem be 949 Racing 6ULs.
                    • 6A LDY
                      • Jul 2014
                      • 318
                      #160
                      You da man
                      1984 MTech1 323i
                        • 34847
                        #161
                        Hows the strut clearance? I'm pretty sure with a 3mm spacer up front, you could fit 225s all around
                        • litu
                          • 849
                          #162
                          Lets put this here also. Not my car, just see it in fb.
                          Rims are 16×8 et 18, tyres are 205/55/r16 toyo NA20..all season
                          There is some lower spring also, but i dont know how much
                          https://www.facebook.com/Cry_77_IX-110483784967661
                          https://www.instagram.com/cry_77_ix/
                          • AWDBOB
                            hooptie connoisseur
                            • Aug 2013
                            • 4516
                            #163
                            Strut clearance is about 3mm (inner lip to strut). I definitely think you're right. It doesn't rub at all, which is nice, but there is definitely a hair of stretch with the 205s on the 8" wheel.
                            I wanted to run a 225 but the RS3s were back ordered again and I couldn't swing R888s just yet. Next time!
                              • 34847
                              #164
                              that looks awful. those wheels stick out at least an inch past the fenders.
                              • litu
                                • 849
                                #165
                                :D :D I liked :)
