iX wheel thread
  • AWDBOB
    hooptie connoisseur
    • Aug 2013
    • 4501
    #106
    Some silver lip, dark grey centered iX weaves would do magic on your car.
    • ScHpAnKy
      • 1573
      #107
      not a fan of iX wheels on iX's actually, definitely too common to really look good - I can appreciate them with spacers on a lowered rwd car though
      91 318i | 87 535iS
      • CrazyPrime
        • Jun 2014
        • 286
        #108
        would 17x7.5 e35 fit and what would be the recommended tire size?
        • TOAST
          • Jan 2006
          • 316
          #109
          thinking about a set of compomotives
          plenty of choices:
          16x7 et18 - 40
          17x7.5 et21 - 40
          17x8 et27 - 37
          thoughts?
          • RocketJohn
            • Mar 2014
            • 88
            #110
            plenty of choices:
            16x7 et18 - 40
            17x7.5 et21 - 40
            17x8 et27 - 37
            thoughts?
            Would love to see some iXs with their wheels
            My Allrad Blog
            • downforce22
              • Aug 2009
              • 3192
              #111
              My wheels (17x7 kosei K1's)
              • ScHpAnKy
                • 1573
                #112
                I'm at ET25 in front and ET15 out back, and run a 225/45/17 on my 17's, which is a huge tire, and only rub out back on launch - with unrolled fenders.
                If I went down to a 205/45/17 I think I'd be happier, and that's what I'd recommend. Welcome to input, however.
                91 318i | 87 535iS
                  • 34844
                  #113
                  ET35 would work fine and you could fit a 225 no problem.
                  why would you run ET15 out back? is the car at stock height? I don't see how that doesn't rub with a 7.5" wheel and a 225 tire.
                  • nrubenstein
                    • 3148
                    #114
                    225/50-15 RA-1s on stock wheels fill out the iX fender wells pretty thoroughly. I can't imagine wanting more.
                    2002 BMW M3 Alpinweiß/Black
                    1999 323i GTS2 Alpinweiß
                    1995 M3 Dakargelb/Black
                    - S50B32/S6S420G/3.91
                    1990 325is Brilliantrot/Tan
                    1989 M3 Alpinweiß/Black
                      • 34844
                      #115
                      yeah, I don't believe that it doesn't rub constantly with unrolled fenders. My 225/50 R888s will even rub a little on the inside of the fender with a 7.5" wheel and ET35 offset, there's barely enough room to slide a paperclip between the tire and the fender lip. 20mm is like 3/4", the tire would be sticking out past the flare.
                      the 235/50s were even worse, they rubbed everytime I went over a small bump or had people in the back, what he's talking about would be significantly worse.
                      • ScHpAnKy
                        • 1573
                        #116
                        I was rounding my results and using fuzzy math, but even then I think my math was wrong, or maybe I don't fully grasp offset calculations anymore. Either way, the specs:
                        E46 wheels (ET47)
                        iX stock offset of 41mm?
                        20/25 spacers, brings me to ET27 in front, and ET22 in back. My apologies.
                        Pics are back a few posts
                        91 318i | 87 535iS
                        • Nisse Järnet
                          • Aug 2013
                          • 1221
                          #117
                          Originally posted by ScHpAnKy
                          thx! :) I wanted to be original and try something nobody else has on an ix, just 20mm/25mm spacers, rear isnt rolled but it eventually should be for hard launches, another pic below (dont mind the missing tails)
                          Looks nice :)
                          E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
                          E30 M50 6 spd 764whp @ 24psi.
                          E30 M20 6 spd 675whp.
                          • Ryan1642
                            • Jul 2014
                            • 81
                            #118
                            Bare with me, Tires and wheels are not my strong point but what makes the ix different from a normal e30 when buying wheels? what wheels can fit a 245/r17 on an IX?
                            I spend 90% of my money and women, cars, and booze. The other 10% is wasted.
                            • The Dark Side of Will
                              • Jun 2010
                              • 2796
                              #119
                              The iX front struts are different, so the offsets of wheels that work with iX front struts are different than what works on RWD front struts.
                              What I've heard is up to 8" wide, ~20 mm offset and 225, *maybe* 235 tires can fit all the way around. The fronts get close to the strut and the rears get close to the fender lips.
                              I'm not sure if going with different front/rear offsets will allow enough more wheel/tire width to make the split worthwhile or not.
                                • 34844
                                #120
                                you won't fit a 225 on an 8" wheel with an ET20 offset. it's more like ET30. 8" ET20 is a RWD fitment. you'd be hard pressed to fit a 205 without massive camber and tweaked fenders or a donk stance.
                                235s fit on my 7.5 ET36 wheels using a 3mm spacer up front to clear the struts. But, the car drives better on 225s.
                                different offsets aren't really necessary.
