24V AWD Swap Knowledge Base
This is a sticky topic.
    • 34839
    #691
    uh, no, the weight reduction is *significant*. the N52 is even lighter than the M54 - it's like 150lbs less than the S54. the cams alone weigh 1/4 of what the S54 cams do (they are hollow!). Magnesium aluminum block, aluminum bolts, everything is optimized for weight.
    plus, it pisses all over any M5x motor in power/torque.
    I already have a CF hood..
    even if I did stick to the S54, I would have to use the E34 parts and I'd have to modify the firewall. and the booster would definitely not fit.
    • King Mufasa
      • Sep 2012
      • 530
      #692
      must consider s54 has extras;)
      even without its itb and intake it is still a beast. Besides all roads lead to boost and s54 is solid. I'm sure the s54 ecu is just as fast too.
        • 34839
        #693
        boost - meh. I'd get an N54 :p
        no, MSS54 is positively ancient. MSV70/80 piss all over it. the S54 powered Z4M used MSS70 which is the same as MSV70 without valvetronic.
        anyway, this isn't a motor vs motor thread. I just want to hear from Nisse on modifying the firewall! :)
        • Nisse Järnet
          • Aug 2013
          • 1221
          #694
          Originally posted by nando
          Thinking about this some more. I'm still considering trying to use some of the E34 parts. I'd have to push the engine into the firewall by about 2", but that would actually help some as the radiator clearance will be super tight otherwise. I did some measuring last night and there'd be maybe 1/2" clearance to the stock E30 radiator. I'd like to run a Z3M radiator for some more cooling, which I don't think will fit with the engine in the stock M20 position.
          I still wish there was something shorter than 3.38 but at least it would be better with the Getrag 260 than the ZF. And I'd get to use the stronger E34 CV shafts that I already have. It's possible I could have a different ring and pinion machined into the E34 diff case. I just can't do it myself.
          who's pushed an engine into the E30 firewall? Nisse? how hard was it and how many things did you have to modify?
          Also, I think I might be able to keep the stock ix booster but only if I go with the custom intake manifold I'd like to build. I might just go for it rather than wasting time/money coming up with a manual setup or hydroboost etc. I'm not sure I'd be happy with either one. I'm still going to run the MK60 DSC setup though.
          Yeah the space between the engine and radiator is great :) Its ~10cm between the M50 valve cover vanos bulge and the rad. (M535 E28 )
          Im in on a diffrent gearing solution in the front diff!
          Its not that hard, but its really tight! I think you have to use really hard rubber engine mounts or delrin (like i do)
          You have to beat the firewall a bit behind the head and above the gearbox, cut and weld behind the valve cover and mod heater fan cover. This is one of the tightest parts if you want to keep the stock heater core and fan. (which i wanted)
          Then you have to beat up the trans tunnel around the TC a bit, mostly to the sides and cut and weld on the drivers side in the tunnel.
          This is also right up against some floor reinforcement that i dont think you would want to cut into too much because the TC is heavy :P
          Then off course custom rear drive shaft, motor/trans mounts and modified outer front CVs.
          Im using the stock ix booster but i modded the spacer bracket a little so it mounts a little lower to clear the intake. (which is custom aluminum btw)
          I can send some pics if you want, might have more than i have posted.
          E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
          E30 M50 6 spd 764whp @ 24psi.
          E30 M20 6 spd 675whp.
            • 34839
            #695
            hmm.. that sounds like a nightmare lol. well, I think I'll keep looking into using the E30ix parts. It's just going to be really tight to the radiator. I might have to pick up the motor sooner rather than later so I can settle on the oil pan & diff.
            • stonea
              • 2892
              #696
              Since the thread was brought back up, does anyone know if you could transplant e46 front diff insides to an e53 x5? I really want to use the e53 x5 oil pan since I'm basically using a M54, but I'm not 100% happy about the 3.64 ratio.
              My Garage
              Feedback
              Instagram: Stone.Hopkins
                • 34839
                #697
                also, the rear driveshaft should have plenty of room for adjustment. shouldn't it?
                do you know how far back you moved it? I think it needs at least 2" with the E34 parts.
                • Nisse Järnet
                  • Aug 2013
                  • 1221
                  #698
                  I replaced the rear diff u-joint with a CV joint (used on many E34, E32 models etc) so there is enough movement there, no adjustability needed.
                  I think its around 1.5" further back but im not 100% sure. And i have no engine in my rwd E30 at the moment so i cant measure right now :P
                  • flyboyx
                    • 8371
                    #699
                    1.5" sounds like the difference between the axle holes of e30 and e34 pans.
                    Gigitty Gigitty!!!!
                      • 34839
                      #700
                      Its 2 1/4"
                      • Nisse Järnet
                        • Aug 2013
                        • 1221
                        #701
                        Under the hood, the red area needs to be "modified" and from the red arrow its aprox 85cm to the back of the engine. (cylinder head)
                        • flyboyx
                          • 8371
                          #702
                          that doesn't look like an ix to me. did you borrow this pic from somewhere?
                          Gigitty Gigitty!!!!
                          • 6A LDY
                            • Jul 2014
                            • 318
                            #703
                            I kind of agree, the strut towers look like they're too far forward for some reason
                            1988 325iX - sold but not forgotten
                            1984 MTech1 323i
                            • Nisse Järnet
                              • Aug 2013
                              • 1221
                              #704
                              Yeah I just took a random E30 pic, not mine :)
                              • The Dark Side of Will
                                • Jun 2010
                                • 2796
                                #705
                                The iX strut towers are father forward than the RWD ones, so I don't know what E30 that would be that has strut towers that look further forward than an iX's... :p ;)
                                It does look like a RWD body, though, as there isn't much space between the battery box and the strut tower.
                                HOWEVER, AWD or RWD doesn't affect the measurements that Nisse showed.
