24V AWD Swap Knowledge Base
This is a sticky topic.
  • Nisse Järnet
    • Aug 2013
    • 1221
    #676
    Originally posted by The Dark Side of Will
    With the number of hubs to choose from, there should be at least one that makes the rotor/parking brake combo work.
    *I* think it's cool too, but the benefit is probably marginal unless you're some Swedish nut pushing over 750 AWHP. ;)
    Yeah think so too, there's also different rotors but i wanted this size to match my fronts. But i dont think ~2mm less hand brake engagement makes that big of a difference :)
    Haha yeah that might be true :D
    E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
    E30 M50 6 spd 764whp @ 24psi.
    E30 M20 6 spd 675whp.
    • Nisse Järnet
      • Aug 2013
      • 1221
      #677
      Just took the car for a spin, seems to work great :D Just have to finish the exhaust and fix a vacuum leak..and put all the body parts back on :P
      • Nisse Järnet
        • Aug 2013
        • 1221
        #678
        Short pull @ 0,3 bar boost...slow :P But it works! More to come :)
        BMW E30 325ix M50 turbo test: https://youtu.be/NGD6IPH0Yis
        • iXguido
          • Nov 2009
          • 730
          #679
          well done! can't wait to see the boost cranked up :D how are you liking your brake setup? and how is your transfer case working with your custom switch?
          • Nisse Järnet
            • Aug 2013
            • 1221
            #680
            Me neither :D
            Its working great! Haven't pushed the brakes too hard yet but so far I love them!
            Tc works great too, with this low power level I don't even need to lock it, 4500 rpm launch control and no wheel spin at all :)
            • The Dark Side of Will
              • Jun 2010
              • 2796
              #681
              Awesome! Congrats!
              Yeah, even with a blown TC, an iX leaves hard. I dropped the clutch on my totally stock 190+k mile '88 with blown TC VC from about 5000 RPM and it just left three 6" long black marks and moved.
              • Nisse Järnet
                • Aug 2013
                • 1221
                #682
                Thanks!
                Haha cool :D Tc lock will probably be more useful with the 2,8 motor :)
                Almost back together
                  • 34847
                  #683
                  Even in peices it looks great! :)
                  So, who will be done next? Will, or me? lol
                  • Nisse Järnet
                    • Aug 2013
                    • 1221
                    #684
                    Thanks :) Hurry up guys ;)
                    BMW E30 325ix M50 turbo test launch 0-160km/h: https://youtu.be/aCMIbW2RZrA
                    • Nisse Järnet
                      • Aug 2013
                      • 1221
                      #685
                      Thirsty :)
                      • stonea
                        • 2892
                        #686
                        ^Now thats a great photo.
                        My Garage
                        Feedback
                        Instagram: Stone.Hopkins
                        • Nisse Järnet
                          • Aug 2013
                          • 1221
                          #687
                          Turned out pretty nice :) Should have put on the hood and skirts though :P
                          • Nisse Järnet
                            • Aug 2013
                            • 1221
                            #688
                            Just checked the cars weight, without driver, 15-20 liters of fuel and no spare tire it was 1290kg. (~2845 lbs)
                            I thought it would be heavier :)
                              • 34847
                              #689
                              Thinking about this some more. I'm still considering trying to use some of the E34 parts. I'd have to push the engine into the firewall by about 2", but that would actually help some as the radiator clearance will be super tight otherwise. I did some measuring last night and there'd be maybe 1/2" clearance to the stock E30 radiator. I'd like to run a Z3M radiator for some more cooling, which I don't think will fit with the engine in the stock M20 position.
                              I still wish there was something shorter than 3.38 but at least it would be better with the Getrag 260 than the ZF. And I'd get to use the stronger E34 CV shafts that I already have. It's possible I could have a different ring and pinion machined into the E34 diff case. I just can't do it myself.
                              who's pushed an engine into the E30 firewall? Nisse? how hard was it and how many things did you have to modify?
                              Also, I think I might be able to keep the stock ix booster but only if I go with the custom intake manifold I'd like to build. I might just go for it rather than wasting time/money coming up with a manual setup or hydroboost etc. I'm not sure I'd be happy with either one. I'm still going to run the MK60 DSC setup though.
                              • King Mufasa
                                • Sep 2012
                                • 530
                                #690
                                ^^ should also stick with an m50 variant motor as you were with the s54 :D. e90 motor are a bit lighter but negligible as the weight reduction is mostly from its manifold, you can always lighten other things like a hood or whatever.. The power band is from its valved intake.
                                I think if you really want that motor it can be have in the future but I think its time for you to put this thing together already, should be real cool to see!!:)
