325ix Axle Rebuild
  • fresh_TD
    • Aug 2013
    • 2457
    #31
    Originally posted by ACVC325ix
    Dang it!
    How far has anyone gotten on making a completely different front diff and CV axle fit on the IX?
    Is rebuilding a sustainable solution or should we be looking to a different font end with parts that are still available?
    The differential is from a Nissan skyline gtr r32 front diff, and cv joints. Machined to fit the original casing. But the the crown gear is the original bmw gear 3,91.
    Log into Facebook to start sharing and connecting with your friends, family, and people you know.
    Sent from my Pixel XL using Tapatalk
    '91 318i (Alpine) - daily
    '88 325ix (Zinno) - drive here and there!
    • ForcedFirebird
      • Feb 2007
      • 8300
      #32
      Dang it!
      Rebuilding is fine, I am doing this set now (well, just a basic re-pack, refresh, and swapping over an outer from a pare axle). I was just hoping that RWD stuff would interchange. I will take measurements from the spare and see about parts for the future, though.
      john@m20guru.com
      Links:
      • nomansland92
        • 1657
        #33
        Dang it!
        With a little cutting and welding a e34 diff and axles can fit.... however if you break those good luck on finding replacements.
        Sent from my SM-G892A using Tapatalk
        IX being restored here
        Ix turbo build here
        • monticello
          • Sep 2007
          • 202
          #34
          I had an axle come apart on me, luckily I was on my way to my friends shop. I lost a couple of the bearings. He had a few old axles sitting in the corner that i disassembled and inspected. The Mitsubishi wasn't even close, the Ford was the same size bearings ( roughly 15mm ). I threw the axle back together with a repack kit and have been driving it for 2 years now without any issues.
          • ForcedFirebird
            • Feb 2007
            • 8300
            #35
            Bearings are the easy part. It's the cages we need to source. The axle I repaired yesterday had a snapped inner cage. Was able to swap a left and right inner CV without issue.
            john@m20guru.com
            Links:
              • 34844
              #36
              This is why I hardly drive the ix now.
              both sets of CV shafts I have click (my original, ~190k set is worse than the ~320k set I have on now, lol). I don't want to risk further damage. Hopefully I can come up with enough 'spare' parts to make at least one good set..
              • 88e30ix
                • Jan 2011
                • 361
                #37
                Will this fit??
                https://www.ebay.com/itm/BMW-325xi-E....c100677.m4598
                Drive it like you just stole it! :p
                • nomansland92
                  • 1657
                  #38
                  Originally posted by 88e30ix
                  Negative ghost rider
                  Ix turbo build here
                  • AWDBOB
                    hooptie connoisseur
                    • Aug 2013
                    • 4490
                    #39
                    I just don't understand why someone like FEQ can't make us decent quality front axles at an affordable price. I wonder if someone reached out how many folks it would take for them to get on board.
                    • ForcedFirebird
                      • Feb 2007
                      • 8300
                      #40
                      Clicking isn't as bad as you think. You probably have gunk in them. It's also a very bad idea to mix grease, they must be 100% clean as mixing of some compounds can actually make the fluid abrasive!
                      ^^^This is the guy who's car is in the shop lol... Hi Paul!
                      eww. FEQ is junk. Had a local put them in his 318is 'vert, and he snapped BOTH in an auto-x, another local put them in his m20-powered 14hr endurance car and they had major play after just one race.
                      I will only supply/install GKN (as new), but I agree, GKN should re-produce them.
                      john@m20guru.com
                      Links:
                        • 34844
                        #41
                        yeah, probably. But they also bind up in reverse at high steering angles. I still think it's funny my set with over 300k miles is in the best condition (and hopefully, as you say, fine). So much for them not lasting long. The other set.. let's just say, I've owned this car since I was like 21, and I may have driven it.. hard.. from time to time. :)
                        anyway, I'm still avoiding driving it as-is, I can't risk damaging the joints if I don't need to. Maybe I'll pull them all apart, completely clean and re-grease this summer. Funny enough, for a decade now I've kept extra boot kits "in stock" because the passenger side always melted from headers, lol. So it's not like I don't have the stuff to do it.. just lazy I guess. I'll try to get the kids to help. ;)
                        • 88e30ix
                          • Jan 2011
                          • 361
                          #42
                          Hey Buddy!
                          • Kershaw
                            • 11822
                            #43
                            If a cage has a crack in it, isn't it possible to have a machine shop weld it and machine it back?
                            AWD > RWD
                            • ForcedFirebird
                              • Feb 2007
                              • 8300
                              #44
                              Welding is possible, but machining hardened steel is another story. :(
                              john@m20guru.com
                              Links:
                              • ACVC325ix
                                • Dec 2016
                                • 123
                                #45
                                I feel like this finding is a big win! There are way more R/passenger side CV's out there than L/Driver's side as far as I can tell. If the cages are interchangeable and the bearings are readily available then unless you physically snap and axle you are golden no?
                                If we can reliably Frankenstein these with parts that last as long as 190,XXX is that not a win?
                                Otherwise having to machine in an E34 solution means being stuck in an inevitable NLA scenario again....
