How to fix hyper flash?
  • PaulEZ
    • Nov 2007
    • 100
    I installed LED bulbs in the front and rear turn signals. I’m now experiencing hyper flash which I assume is due to the lower draw from the LED’s.
    I bought a 3-prong “led” flasher relay to swap out the stock relay but it didn’t work. In fact, the neither the turn signals or hazards worked at all with the new relay.
    What are you guys using? Do I need to install load resistors? Any recommendations?
  • Gregs///M
    • Mar 2012
    • 2459
    Yes you will need a load resistor for each LED assembly you install.
    Owner - Bavarian Restoration
    BMW and European Electronics Repair and Restoration
    www.BavRest.com
    My Feedback Thread
    Our Facebook!
    Follow our Instagram!
    • PaulEZ
      • Nov 2007
      • 100
      Thanks. Is their a specific wattage and ohm resistor commonly used on our cars?
      • Gregs///M
        • Mar 2012
        • 2459
        You will need to match the electrical characteristics of each bulb assembly you replace.
        www.BavRest.com
        My Feedback Thread
        Our Facebook!
        • monty23psk
          • Mar 2008
          • 1289
          I buy all my LEDs from superbrightleds.com. I have LEDs in the rear and still incandescent in the front. I had hyper flash, then bought their flasher relay and no issues. No idea if it is because it is all from same brand, which I doubt. I can provide PNs if you want, just need to look them up.
          Alex 88 m5 | 91 318is | 19 Subaru Ascent
          BMW Tool Rentals & Fender Roller
          • TobyB
            • 5261
            I had hellaflush until I turned down the water pressure to the toilet...
            t
            plunging
            • Jaxx_
              • Dec 2009
              • 1880
              I have a flasher relay as well that worked fine... a few custom LEDs in the front and a full replacement LED bulb in the rear. I think I purchased the generic LED flasher relay from Autozone that matches the pinout for our cars. 3 pin with one being "L"? Maybe I have that wrong.
              • moatilliatta
                • 6149
                A guy on ebay sells a modified Anti hyper flash relay. Used it in my E36.
                @Zakspeed_US
                • Staszek
                  • 2533
                  Load resistor.
                  • PaulEZ
                    • Nov 2007
                    • 100
                    Ok I’ll keep trouble shooting and report back when I find a solution. Thanks everyone!
                    • PaulEZ
                      • Nov 2007
                      • 100
                      Found a flasher that works: https://rover.ebay.com/rover/0/0/99?...p%2F1024434477
                      You just have to make sure the battery and signal wires match up with the relay correctly. Mine were backwards. Apparently our with the old/original relays it didn’t matter but the LED relay has to be wired correctly.
                      • Synr
                        • Sep 2021
                        • 31
                        can i ask for those part #'s?? even though this thread is older i doubt i'll get an answer.
                        • monty23psk
                          • Mar 2008
                          • 1289
                          Originally posted by synr
                          can i ask for those part #'s?? Even though this thread is older i doubt i'll get an answer.
                          cf13gl-02
                          • Synr
                            • Sep 2021
                            • 31
                            cf13gl-02
                            god bless you kind sir
