How to install a killer stereo for $500 (loads of pics)
This is a sticky topic.
  • StereoInstaller1
    GAS
    • 22679
    #346
    Originally posted by htown318is
    non-premium sound car
    Infinity Reference 1262w 12-Inch 1200-Watt
    Planet Audio AC1800.5
    E3012 Lukebox
    = WIN ?!
    Absolutely...that combo is one I have done several times, it is incredible.
    Was that your 12" E30 box that went out yesterday?
    Closing SOON!
    Thanks for 10 years of fun!
    • StereoInstaller1
      GAS
      • 22679
      #347
      Picture of a gutted seat? How far do you guys cut out the foam? I have a Weller soldering gun with a hot knife attachment that seems to be perfect for the job.
      Originally posted by NitroRustlerDriver
      Hot knife would be messy and smell bad. A sharp serrated bread knife or electric turkey carving knife works much better. Even a sharp utility knife works.
      I know there are some good pics somewhere, I will see if I can find them.
      I have only ever tried using a utility knife, I just kind of cut the skipass hole and take out 2" maybe 3" over the whole area. I use kind of a "sheep shearing" technique and pull the foam back and cut under it, a few inches at a time.
      I am sure there are smarter, cleaner methods..but the whole thing takes like maybe 5 minutes so I have never even thought about it.
      Closing SOON!
      • Rmlr
        • Jun 2013
        • 62
        #348
        Luke, I still have the foam portion that i took out. So putting it back with some adhesive should be bad. The flapping of the vinyl is just too annoying and ruins he bass completely.
        Now when you say vertically, The ports opening would face the roof of the car? or Ports through the seats with openings facing the front of the car? A little confused about the orientation :) Even a rough sketch may help i guess. I have some PVc piping lying around that I could use. I should have asked you before gutting the seats out!
        Rahul, you should port your seat. Find another seat if you must, but cut your foam down about 2" in the ski pass, make sure you don't go through anywhere and do 2 4" ports , try to keep them as short as possible to prevent interactions, and put them in front of the woofer, vertically.
        • StereoInstaller1
          GAS
          • 22679
          #349
          Closing SOON!
          • Rmlr
            • Jun 2013
            • 62
            #350
            ^I was hoping the solution did not involve tearing into my Mint Tan Seats! Oh well..think I will get it to it when am finally sick of the vinyl flapping around..Thanks again Luke!
            • htown318is
              • Feb 2012
              • 301
              #351
              nope.. but I did just put a e3012 order in recently :D !!!
              • StereoInstaller1
                GAS
                • 22679
                #352
                Yes you did and thanks, it will be out shortly
                Closing SOON!
                • theycallmebrown
                  • Jun 2014
                  • 28
                  #353
                  Luke, would it be ok cut in to the vinyl and stop so that the look remained stock? I'm just thinking about some poor kid having to sit on those... and if i did just cut the vinyl, you recommend cutting all the way to the vinyl, half way, or should i just man up and cut through it?
                  • StereoInstaller1
                    GAS
                    • 22679
                    #354
                    OK, so here is the issue: there is a layer of slippery teflon-like plastic between the vinyl and the foam. It's just sort of plastic sheet, its no big deal, but it buzzes and flaps bad without the support of the foam behind it.
                    If you DON'T do what I said, meaning cut out ONLY 2" of foam all over the skipass, you will have a nasty rattle where the teflon feeling stuff rattles and flaps against the foam and vinyl....so, let me say this again:
                    DO NOT CUT THROUGH ALL OF THE FOAM
                    Luke
                    Closing SOON!
                    • george graves
                      • 19997
                      #355
                      2" into the foam? Or 2" away from the back side? Front side? The side that you see?
                      Originally posted by Matt-B
                      • theycallmebrown
                        • Jun 2014
                        • 28
                        #356
                        i think what he means is to stick your arm in from the trunk and trace around the ski pass through onto the back side of the foam with a marker. then take the seat out, using a razor cut around that outline 2 inches deep and carve it out keeping it only 2 inches deep.
                        • StereoInstaller1
                          GAS
                          • 22679
                          #357
                          EXACTLY! Thank you, sometimes I have a hard time explaining my thoughts.
                          The chunk you end up with (you are a god of foam carving if it is only one and not 30) should be 2" thick. You can take a bit more, but the goal is 2" removed.
                          Closing SOON!
                          • DER E30
                            • Sep 2013
                            • 2349
                            #358
                            I'll have to try that...
                            -Christian
                            • htown318is
                              • Feb 2012
                              • 301
                              #359
                              got it all hooked up. took me a while to clean up PO's left over cut up shit that was still in there..
                              this thing sounds crazy crazy crazy. step out the car shut the door, youll never know the radio was on. open it up and get ready to step in, its booming like a nightclub in there.
                              im still learning how to tune this ac 1800.5 as this is my first amp powered system ever. not touching the bass boost based on all the scary stories I read LOL.
                              only thing that worries me is that my empty trunk gets hot.. so I can go in there and the amp is already warm to the touch after it sat overnight.. and when I ran it for a good hour.. the amp was really hot. I could keep my hand on there, but I didnt really want to.
                              I followed the guides on stock wiring with fader as best I could and made sure all the connects were solid.
                              is this normal? otherwise, this is the sickest sound Ive heard under 2-3k.
                              • AndrewBird
                                The Mad Scientist
                                • 11898
                                #360
                                It shouldn't get hot to the touch. What subwoofer are you using and how do you have it wired? Sounds like an impedance issue to me.
