How to install a killer stereo for $500 (loads of pics)
This is a sticky topic.
  • MPLFoster
    • May 2013
    • 1490
    #391
    Originally posted by mikerob97
    So in general, sounds like folks like the stock premium sound speakers over other $75/pair price point speakers?
    That's what i'm doing. Considered getting new components but after reading what people have to say about the OEM premiums i'm going to give them a shot. pretty stoked for this set up.
    Ready to go! :up:
    bump for an awesome vendor and a great write-up.
    form.follows.function IG @mplfoster
    • azndeugene
      • Sep 2013
      • 192
      #392
      Bump for a great write up, amazing service, and a magical product. The 10" Lukebox is inexplicably magical!
      1986 325
      1988 325is 2.7 Stroker
      • chad h
        • Oct 2014
        • 21
        #393
        So i put in my amp and am still getting buzz/whine. I moved the ground and it didn't make much of a difference, i made sure i scraped off paint. My power cable is running down the passenger side with my rca's on the drivers side. I'm running out of ideas.. Is it time to get filters for the system?
        • DER E30
          • Sep 2013
          • 2349
          #394
          How's the ground on the HU? Ground the ends of the RCAs?
          -Christian
          • chad h
            • Oct 2014
            • 21
            #395
            Tried using a different ground on the HU, no difference.
            Grounding RCAs? May need some explanation on that..
            • StereoInstaller1
              GAS
              • 22679
              #396
              Chad, it's a dirty old installer trick that doesn't always fix things on modern gear.
              What he is talking about is putting chassis ground to the shield of the rca.
              Grab a foot or two of wire, connect it to the decks chassis. Strip back the other end, start the motor, play the system and see if touching that wire to the outer ring of the rca fixes it. If it does, solder a wire to each RCA and ground them all
              Closing SOON!
              Thanks for 10 years of fun!
              • DER E30
                • Sep 2013
                • 2349
                #397
                This.
                I did this on mine and it got much quieter... I think I popped the pico-fuse business in my deck hot swapping the RCA's, I did that and it was much better. No more blower noise!
                SO don't swap RCAs with the system on people!
                -Christian
                • StereoInstaller1
                  GAS
                  • 22679
                  #398
                  I think the cheaper gear means weenier picofuses, tiny little SMDs that just take the abuse.
                  All in all, yeah, turn it off before you unplug it
                  Closing SOON!
                  • gwb72tii
                    • Nov 2005
                    • 3864
                    #399
                    I just want to give a shout out to Luke. I can repair almost anything mechanical, but electronics/electric circuits not so much.
                    Luke spent probably an hour texting me, holding my hand (sorry blunt I still love you) and got me to the finish line. What seemed like arguing from me really was my ignorance about electrical things showing thru.
                    The result was sort of like starting a motor for the first time after rebuilding it. You sort of hold your breath and try to remember anything you didn't do.
                    Fuck me my sound system sounds great.
                    So here's to you Luke. Glad your moving to the harbor. Next drink's on me.
                    Thank you.
                    “There is nothing government can give you that it hasn’t taken from you in the first place”
                    Sir Winston Churchill
                    • Mr. Tasty
                      • Jul 2011
                      • 3421
                      #400
                      going to be picking up a buddies setup that followed your cookie cutter build for the most part. Only issue is that he has the sport audio with the factory amp. The car I will be putting this into is a 1987 325e with regular audio. Is there a DIY for a non-sport audio car?
                      2014 Alpine White 335i MSport
                      (Daily Driver)
                      Full Mperformance Aero
                      KW V2 Coilovers
                      VRSF Catless Downpipes
                      • StereoInstaller1
                        GAS
                        • 22679
                        #401
                        I have got to get that done! Yes, it's actually covered in this thread, but I think I need to re-organize the installs, since there are 5 different wiring schemes in E30 alone
                        Closing SOON!
                        • StereoInstaller1
                          GAS
                          • 22679
                          #402
                          Yeah, the Premium Harness makes it easy, unless you were to do the "Classic" PCN, which would wipe out your whole budget.
                          BTW, killer deal on an amazing performing but absolutely hideous amp: http://www.sonicelectronix.com/item_...-MB-Quart.html
                          Closing SOON!
                          • Sh3rpak!ng
                            • Jan 2014
                            • 2667
                            #403
                            Hey luke, do you have any new suggestions for an affordable (less than $200) 5 channel amp?
                            Can't find the jensen 5500 anymore and that link to the amp above is discontinued :(
                            Shadetree30
                            • StereoInstaller1
                              GAS
                              • 22679
                              #404
                              Ya, just hit any online vendor and look. There's an incredible deal on Sonicelectronix.com right now, a Powerbass 700.5X for 120 shipped!
                              Closing SOON!
                              • Sh3rpak!ng
                                • Jan 2014
                                • 2667
                                #405
                                Thank you sir!
                                Shadetree30
