How to install a killer stereo for $500 (loads of pics)
This is a sticky topic.
  • StereoInstaller1
    GAS
    • 22679
    #451
    Originally posted by TrentW
    Got the trunk tar out today and realized my IE rear sway bar mounts are going to interfere with the Lukebox. Anyone else have this issue? Really don't want to have to modify the box, but it's only about an inch or so on each side.
    No, they fit fine, I've done a bunch. Make sure the "head" side of the bolt is up and it's all good
    Closing SOON!
    Thanks for 10 years of fun!
    • The White Guy
      • Jul 2012
      • 144
      #452
      Trent,
      Yes, I had the very same problem. I was going to router out a shallow channel
      for bolt head clearance on each side of the enclosure. Instead of that, I went with countersunk allen head screws and countersunk them flush with the trunk floor.
      (Do one bolt hole at a time to keep alignment good)
      I also put 3M sealant under the countersink heads just because I am OCD.
      Got the bolts from these guys: Belmetric.com I think that they were part #SF8X30SS.
      Stan
      • theTBLACK
        • Jan 2013
        • 156
        #453
        So I just read through the first bit of this thread -
        I have a 318i with stock sound and really want to upgrade + your box.
        Best route to take?
        Founder
        TheDirtyThirty
        instagram.com/thedirtythirty
        • The White Guy
          • Jul 2012
          • 144
          #454
          Best route to take?
          Contact LUKE @ G.A.S...
          He will steer you right.
          Stan
          • DER E30
            • Sep 2013
            • 2347
            #455
            Stan
            Quoted for truth
            -Christian
            • Rouvld
              • Sep 2014
              • 569
              #456
              Just ordered my 10" lukebox for my m3, can't wait to get it!
              • mxtx
                • Jan 2016
                • 158
                #457
                i've seen mention of this Touring box here and on G.A.S. site... has anyone actually installed? pics would be great.
                i have no doubts the sound is awesome since any open hatch is great for acoustics as i've had in previous cars but, unfortunately, at this point in my life i actually need the trunk space so debating how far i don't have to go to get a little low-end.
                any other Tourings with sound setups and decent bass without a full box? underseat woofer or other alternatives? please describe.
                thx.
                '89 E30 Touring, '85 911 3.2 Coupe, '89 GB500, '96 XR400
                • StereoInstaller1
                  GAS
                  • 22679
                  #458
                  thx.
                  We are getting an E30T here shortly, with the goal being a completely hidden system, with the sub in the spare tire well, like we've done on a few E34Ts.
                  Get in touch if you are interested, but don't have any expectations of a time frame, this is going to be a damn long process, since the car is 2 hours away and currently isnt driveable
                  Closing SOON!
                  • mxtx
                    • Jan 2016
                    • 158
                    #459
                    sure yea, im interested. i have no expectation of timeframe just interested in what others do with their tourings for sound so it will be good to see no matter when. please update your progress, looking forward to seeing it. thanks.
                    • StereoInstaller1
                      GAS
                      • 22679
                      #460
                      Sure! Soon as our man in Portland gets his clutch issues figured out, it's coming up to us. He also just became a father, so he has plenty on his plate already.
                      Hopefully some good answers soon!
                      Luke
                      Closing SOON!
                      • BlackSpeed66
                        • Apr 2008
                        • 618
                        #461
                        So - after like 2 years, I finally got half of the crossovers and the LukeBox i recently received installed. (yeah there was an s52 swap in the middle there that I couldn't pass up so the audio got put on hold). Anyway, here's some pics...
                        Yes Luke, I'm still running the RMT 200 as a head unit... :giggle: :-D
                        I strongly recommend the dry-ice method to remove the trunk tar. Barely took 45 minutes. Just don't be too over zealous on the hammer otherwise you will dent the floor! I bought 10lbs but i think 15lbs of the pellets would be more sufficient to cover the surface.
                        Before:
                        After: the little white bits are pellets of dry-ice.
                        I went w/ the Infinity 1062W
                        Installing rear PCNs. Still have to figure out the front ones -there's not a lot of space in the kick panels and with the tweeters in the door it complicates the wiring a bit....
                        All tidied up!
                        Made extra sure the wiring's not going anywhere as this car will see the track again!
                        I also hacked out several inches of foam from the center area of the rear seat back. I was listening to Tool without the seatback with the engine off the other night. I heard a noise that i thought was something in the garage so i spun my head around. I laughed because I then realized it was the high toms on the drum kit. I think that sort of reaction speaks volumes about the quality of the sound and construction!
                        -Geno
                        '87 325is (s52'd)
                        '95 525iT
                        '02 Range Rover 4.6 HSE
                        '98 Disco 1
                        • StereoInstaller1
                          GAS
                          • 22679
                          #462
                          Geno, thats brilliant, thanks!
                          Closing SOON!
                          • agent
                            Vice Grand Pubaa
                            • 7960
                            #463
                            The StreetWires 4 AWG amp kit is only $18 on Amazon right now, which is the least expensive I've ever seen it. I used this kit when doing my install in Klaus and paid about twice that.
                            https://www.amazon.com/gp/product/B003J59XTM/
                            Originally posted by kronus
                            • piwko98
                              • Apr 2016
                              • 52
                              #464
                              Luke
                              Luke - any luck on the SUB in the spare tire spot? No rush here but would be a great to have a hidden one in my vert.
                              • StereoInstaller1
                                GAS
                                • 22679
                                #465
                                Nope, Ive done too many, it sounds like ass in a vert, I won't touch it
                                Closing SOON!
