My Favorite $30 Mod so far...(keyless entry)
This is a sticky topic.
  • BrooklynMW
    • 1263
    #331
    German overhead check panel. Completely useless, but totally cool.
    '87 325i "Chewey" (RIP, my beloved)
    current:
    '01 e46 325iT "Dot" - #datwagonlife
    '87 e30 325i "Tui" - she has her mother's eyes
    • bmwman91
      • Oct 2004
      • 3134
      #332
      My how-to install article:
      http://bmw.e30tuner.com/articles_rec43t.php
      Transaction Feedback: LINK
      • Pennyw1se
        • Jul 2009
        • 121
        #333
        I installed this yesterday using the above guide. Very easy and straight-forward install.
        • boosted_E30
          • Dec 2010
          • 173
          #334
          Originally posted by bmwman91
          Bought one of bmwman91's spare Omega units, and used his install article here and works like a charm!
          Thanks again!
          • bzboardz
            • 1096
            #335
            installed this using a bulldog system. very easy, only problem was finding how to secure the unit in the trunk
            • e30BMart
              • Feb 2011
              • 658
              #336
              Originally posted by equate975
              What make and model of keyless system are you guys getting? All the ebay links that were up are invaild now.
              Try this: http://www.rclick.co.uk/product_info...roducts_id=674
              • e30BMart
                • Feb 2011
                • 658
                #337
                Originally posted by BrooklynMW
                Ok, you know I love you guys right? But so far, the only thing anyone has to say on this forum is how cheap the REC is, how easy it was to install, and how much they love it.
                Meanwhile, I seem to be having a real problem figuring out how to get mine to work, been posting up questions and requesting advice for days, and so far nobody has had anything to say.
                I'm sorry, I'm just losing my patience with this damn thing, and I need freaking help!
                The only possible reason I can think of is that there is a problem with the central locking system's wiring in a place that isn't visible. Other than that, I don't know what I could be doing wrong. I followed all the directions, wired everything up properly, programming the transmitter properly, and yet, still no worky.
                AAAARRRRGHGGG!!!!
                When you lock you're door on the driver side with your key do all your doors lock? If you lock your driver door and want to test your keyless after don't activate the deadlock because often these remotes won't operate with deadlock on. man I don't know what to say, test voltages and shit
                Goodluck D':
                • bmwstephen
                  • 2463
                  #338
                  If the alarm offers Door Trigger Input wires are they even applicable on our cars? I don't see how they work
                  • StereoInstaller1
                    GAS
                    • 22679
                    #339
                    Stephen, I am gonna send you pics soon, but the green wire on your Scytek goes to the brown/purple behind your speaker. It gets a signal from all doors, but not hood or trunk.
                    Closing SOON!
                    Thanks for 10 years of fun!
                    • bmwstephen
                      • 2463
                      #340
                      appreciate it luke. sorry to bug you. I figured you were busy so I decided to just research on the side to clean up that hack job. also I've been reading your old posts where you mentioned that the keyless entry requires a relay in the alarm. I'm not quite sure if my alarm has that been I've been able to unlock and lock just fine. also, do e30's even have a trunk trigger? I'm getting info where some people say they do while others don't
                      • StereoInstaller1
                        GAS
                        • 22679
                        #341
                        There is a trunk trigger, but it is only from the switch to the light, it does not go outside the trunk lid.
                        Your G20 should have 2 relays (for lock and unlock) or it will die soon.
                        Closing SOON!
                        • bmwstephen
                          • 2463
                          #342
                          Luke, what exactly does this tap do? As you can see on my alarm's diagram, I have one positive and one negative for the door trigger. I tried plugging each one in one at a time and testing for any changes and behavior and as far as I can tell it might as well not be tapped at all.
                          • bmwstephen
                            • 2463
                            #343
                            bumpy!
                            • mRodiek
                              • 597
                              #344
                              Scratch that, figured it out.
                              Just ordered from RightClick, $60 US.. Ill post pics when installed
                              Originally posted by e30lov
                              sweet a mk4 jetta, haven't seen one of them for about 14 seconds
                              Adventures of an E30
                              • BergerNJ
                                • Oct 2009
                                • 349
                                #345
                                None of my locks work....Only the passenger side and my trunk lock from using the key.
                                When I use the trunk lock none of my locks go with it...So I'm guessing my car doesn't have central locking? Or is there a proper diagnosis to go about finding the problem with the central system??
                                I'm guessing if there is, I should start with my drivers side door because that lock doesn't even work...Its hard to get it to turn, and then it doesn't even lock...
