rear wheel bearing job w pics
  • mr.
    • Jun 2013
    • 513
    #151
    Originally posted by jeffnhiscars
    The beating is sealed and lubed at the factory and a little light oil on the outside will help it install
    Awesome, no grease needed at all though?
    • b*saint
      • 3794
      #152
      Greasing the outside will help it slide in. And before someone chimes in, this will never cause the outer race to spin.
      I do these types of bearings in hubs all the time from BMW to Fords.
      Ma che cazzo state dicendo? :|
      • jeffnhiscars
        • Jun 2011
        • 6011
        #153
        Grease will harden and be a pita later...if there is a later. Avoid it
        Alice the Time Capsule
        • b*saint
          • 3794
          #154
          Come on now, no it wont. Im pretty sure if a bearing puller can overcome the interference fit of the hub and a bearing thats been stuck in there for 30 years, it can overcome a hard dried FILM of grease (if it ever gets to that point.)
          Like I said, I do these all the time.
          • mr.
            • Jun 2013
            • 513
            #155
            Thank you both for your responses, now which one to trust? Haha
            What about a thin layer of anti-sieze in the TA housing and around the inner race?
            • jeffnhiscars
              • Jun 2011
              • 6011
              #156
              grease does not compress which is why it's used to drive out pilot bearings so it will lend nothing to the installation or life expectancy of a bearing.
              neither Bentley nor the factory service manual recommends it but it's your car so do as you see fit
              • Grackle
                • Jul 2015
                • 119
                #157
                What is the torque spec on the axle nut? Anyone know?
                • estoguy
                  • May 2013
                  • 1087
                  #158
                  145-155 ft lbs according to Bentley.
                  Estoguy
                  • Grackle
                    • Jul 2015
                    • 119
                    #159
                    Cool, thanks!
                    • estoguy
                      • May 2013
                      • 1087
                      #160
                      Cheers bro... how'd you make out?
                      Estoguy
                      • Grackle
                        • Jul 2015
                        • 119
                        #161
                        Got the driver's side apart. The passenger bearing is OK, but the driver's side was hosed. Was able to make this tool out of some scrap aluminum from work, some all-thread I already had, and about $3 in washers. These are not fun to remove.
                        • Grackle
                          • Jul 2015
                          • 119
                          #162
                          OK, apparently there are different bearing sizes. The ones I received for an 86 325es are much smaller then what is on the car. Best as I can tell my car has had the driver's side trailing arm replaced with a later model trailing arm that takes a bigger bearing. I don't know about the passenger side as I have not taken it apart yet. I likely will just put the passenger side back together since it wasn't making any noise anyway.
                          This is the measurements/type of part I bought:
                          http://www.oreillyauto.com/site/c/de...eyword=513113+
                          This is what I pulled out of the car:
                          http://www.oreillyauto.com/site/c/de...keyword=513106
                          So a 39mm ID, 72mm OD bearing is listed as what is supposed to fit my car. But it actually takes a 42mm ID, 75mm OD bearing.
                          ETA: According to realoem the cutoff date is 09/85 for the smaller bearing, so the vendor I got my bearings from is wrong (my car's build date is 05/86).
                          • RondoAcapriccio
                            • Jul 2011
                            • 524
                            #163
                            when driving the wheel hub in, it became difficult mid way through and it stopped turning as I using the ratchet, then it went in. However now the hub kind of sags, and I can see the inner race has some play. If I tighten it all the way it wont sag but the minute I go to undo the driver (HF OTC HUB PULLER EQUIV) it will become loose and sag again. Did I fuck it up, also can I just put the axle in and once I tighten the axle nut it should all be good though right?
                            • reelizmpro
                              • 9558
                              #164
                              Many aftermarket parts vendors will give bad info regarding cutoffs and compatible models. I would go by RealOEM as a source to double check you are getting the right part.
                              Did you make sure the hub was pressing in evenly? IIRC, you were supposed to use the right diameter cylinder to keep the inner bearing race from moving while pressing the hub in.
                              From the original post...
                              "Installing hub. Same concept as before. Plate over hub to draw it into the wheel bearing, except this time the plate on the OPPOSITE side is only bigger than the INNER diameter of the wheel bearing."
                              I would make sure there is no play or sagging at all before installing the axle. You may even have to replace the bearing again at this point.
                              88 M3 - LACHSSILBER
                              89 M3 - ALPINEWEISS II
                              • Grackle
                                • Jul 2015
                                • 119
                                #165
                                Yeah I used realoem to verify what I was seeing.
