Help with new MSPNP2
  • Hoffbrohaus
    • Sep 2013
    • 519
    #31
    Originally posted by kyleconstantine
    Nice 82 sounds much better. Make sure you turn it back from fixed angle to use table now that the timing is set.
    Yes thanks for the reminder, I did it but was hours later when I remembered myself.
    I get my M50 TPS Friday and then I was thinking I might as well go wasted spark. Looking at buying this '95 Saab Coil pack and the quad spark from DIYAuto. Opinions?
    and If I go wasted spark what do I do with the old cap & rotor? Leave it disconnected or buy a $50 block off plate ?
    '90 325is
    • varg
      Florida Turbo Man
      • May 2014
      • 3400
      #32
      I just left mine open to the elements. Maybe inadvisable, but there are more manufacturing steps than I care to involve in making my own a block off plate, with the recessed channel on the back, counterbored hardware, filleting of the edges. I can see how in low volume they wind up that expensive. I would 3D print it but I think I'm better off with nothing there, honestly. That's a rough spot for a 3D printed part; directly in the hot radiator fan wash, exposed to significant vibration. You could probably get one without the recessed channel cut from a simple CAD model and countebore the holes yourself for cheaper than $50 if you use one a cheap service like sendcutsend. In my experience getting the end tanks plates cut for my E34 I don't see such a simple part being very expensive at all.
      IG @turbovarg
      '91 318is, M20 turbo
      • Panici
        • Dec 2009
        • 2463
        #33
        I've got two quadspark modules on my MS3X.
        They need to be kept cool or you will start to get misfiring. A heatshield wasn't enough when I had them mounted below the battery tray. Ended up mounting them inside the car.
        '87 BMW E30 325is Turbo
        '98 BMW E36 328i
        • kyleconstantine
          • Apr 2014
          • 1380
          #34
          I run quadspark and diyautotunes ign-6 coilpack. In a jam it's the same as a duralast coilpack part #c881 from a 1997 dodge intrepid 3.5. definitely mount the quadspark in the car. Mine is on the firewall behind the ecu. I melted a couple in the engine bay and ruined the coilpack at the same time before I figured it out.
          • kyleconstantine
            • Apr 2014
            • 1380
            #35
            I really wish the megasquirt came with the ignition drivers inside the ecu already as the extra wiring is ugly to me and given me the most problems. Not that my car isn't a ratrod...
            • Panici
              • Dec 2009
              • 2463
              #36
              If I was to redo my setup I would change to a different COP with built-in igniters/drivers.
              Could trigger these directly from the ECU without separate boxes and wires involved.
              '98 BMW E36 328i
              • Hoffbrohaus
                • Sep 2013
                • 519
                #37
                Thanks I'll do that especially since I am in Phoenix. If I drive a turbo in the summer everything will melt. Now why would you run two quadspark modules? I thought you only use 3 of the channels anyway, now you have 8.
                Is there a way to do this? I could skip the quadspark and go with a coil that has built in ignoters/drivers.​
                '90 325is
                • kyleconstantine
                  • Apr 2014
                  • 1380
                  #38
                  Yeah that's another case of I should have spent the money the first time. I have plans to go megasquirt 3 and I'd def do cop and full sequential with a cam sensor.
                  • kyleconstantine
                    • Apr 2014
                    • 1380
                    #39
                    Is the ms2 capable of driving the cop directly in wasted spark mode without the quadspark? I thought you needed a ms3 for that. I started to say it wasn't but I don't wanna put up bad info.
                    • Panici
                      • Dec 2009
                      • 2463
                      #40
                      Two quadspark modules for full sequential control on the MS3X. Using three channels per module, which should also keep them a little cooler running at 3/4 capacity.
                      I haven't looked into it in any detail, but I have heard of COPs existing with built in igniters/drivers. They are just triggered by a 5v/12v logic level signal, which the ECU puts out (currently to the quadspark modules in my build).
                      '98 BMW E36 328i
                      • varg
                        Florida Turbo Man
                        • May 2014
                        • 3400
                        #41
                        Yes. You can easily install BIP373s or IGBTs and drive a COP or wasted spark like that saab V6 coil pack directly. You can also drive M50/M42 coils and most others for that matter directly with installed ignition drivers in MS2. MS3X is a totally different animal, while you can install additional drivers in it, it makes more sense to use the logic level outputs do drive coils which have internal high current transistors. MS2's biggest limitation in our turbo applications is that it can't do sequential injection, this hampers fuel economy and idle quality since you're forced to use simultaneous 1 injection per cycle to keep your pulsewidths in a reasonable range if you have large injectors. 6 injectors firing at once on mostly closed valves harms idle quality and low engine speed fuel economy for obvious reasons.
                        IG @turbovarg
                        • kyleconstantine
                          • Apr 2014
                          • 1380
                          #42
                          I used to have the bip373s added in my ms2 case but I always had issues with them burning out and taking the coil with them same with the quadspark. Finally got a working set up. I think the logic level outputs sound nice and going full sequential. I've already picked up a mrt plate with a cam sensor.
                          • varg
                            Florida Turbo Man
                            • May 2014
                            • 3400
                            #43
                            Interesting, how did that happen? I've never burned an ignition driver, and I've had 3 different daily driven MS setups and have tuned or helped tune dozens in my estimation. Knock on wood, I suppose, I have found in-case drivers perfectly reliable.
                            IG @turbovarg
                            • kyleconstantine
                              • Apr 2014
                              • 1380
                              #44
                              We'll my soldering skills came from building vintage tube amps with huge solder pads. I was shocked when I attempted to build my first ms2 from scratch. So it was probably my soldering error. I did get it working after a couple attempts. I had a pnp made by a member in a stock ecu case for my next car and the bip373s we're grounding themselves to the case. Ended up frying that board. Then when the quad sparks came out I think I over heated it by having it in the battery tray. My current set up has been working flawlessly but that's how ms has been for me. Lots of learning the hard way.
                              • Hoffbrohaus
                                • Sep 2013
                                • 519
                                #45
                                So I had emailed DIYAuto asking some questions about quad Spark and the Saab coil pack. Turns out they're working on a coil pack with built-in logic drivers.
                                I called in to pay for a test one. When I get it I'll take pictures and let you know how it goes. They said it is a gm coil pack and looks a lot like the Saab one I sent them a picture of, so my spark plug wires might plug right in.
                                Shipping today from GA to AZ.
                                '90 325is
