Megasquirt Setup Help is needed 🙏
  • sgalich
    • Nov 2025
    • 2
    Hey y’all!
    I have a 1988 BMW 325 (Super ETA) — stock N/A M20 2.7 block with a 325i intake manifold. I installed a Megasquirt PNP Pro but can’t get it properly tuned. There are plenty of issues, and they seem to change every time I tweak the settings a bit.
    A few examples:
    - The ECU shows “Idle” status on TPS around 1–5%, and the car jerks when it switches between Idle and Cruise.
    - Idle speed randomly fluctuates.
    - When I enable the TunerStudio autotune feature, idle RPM suddenly drops below 800 and the engine stalls.
    - At full throttle, it runs for a few seconds and then the AFR Safety system cuts fuel completely.
    Is there anyone in the Austin, TX area who can set this up for me once and for all? I’m just exhausted and don’t think I can sort it out myself anymore.
  • It's Soda Not Pop
    • Jan 2022
    • 877
    Email Jake at Classic Daily
    We have a load bearing linked AWD Dyno in house with multiple logging abilities.  We are able to tune a multitude of platforms, including GM (HP Tuners), BMW (MS42,MS43,MSA41,motronic), Standalone (fitech,holley, megasquirt, vems, etc).  If you need something as simple as a DOD/AFM delete on your 2008+ GM truck or a co
    88' Seta 2.7i Zinno
    https://www.r3vlimited.com/board/for...430-my-88-seta
    • varg
      Florida Turbo Man
      • May 2014
      • 3413
      Isn't classicdaily in Michigan?
      Tuning requires a systematic approach. If you're seeing the idle flag when you shouldn't, you change your engine state settings. If it's going lean at WOT, you add some to the VE map where it happens until it doesn't, start by adding 10% across the whole WOT area of the map. Auto tune is for refining a map that is already running fine to target values, not for fixing problems with a map that is so off base it doesn't even run right. The AFR safety cutoff ratio is adjustable, too. I'm not sure what your base map/default setting is, but verify it isn't set aggressively like it would be on a turbo car, stock M20s run surprisingly lean at WOT and if your AFR safety kicking in at 12.5:1 or something it's not helping anything tuning a car that stock was seeing 13-14:1 at WOT on motronic.
      IG @turbovarg
      '91 318is, M20 turbo
      • CZero
        • Jun 2025
        • 13
        Originally posted by sgalich
        Hey y’all!
        A few examples:
        Did you ever figure this out? I emailed classicdaily also but since it's a holiday week I figure I might not hear back until next week. My car is on MS 2 pnp - when I give a little throttle it just goes completely lean, once I'm past about 2.5k rpm it starts to run ok, but I'm pretty new to tuning so I'm trying to research what I don't know, which is hard to do when you don't know what you don't know, lol.
        • sgalich
          • Nov 2025
          • 2
          Kind of. Two things helped a lot: I replaced the cheap TPS sensor with a proper one, and I found a settings file that mimics the stock Motronic setup. Uploading it basically wiped out all my messy tuning, and the car started running properly.
          After that, I added some upgrades, including a more aggressive camshaft and a lightweight flywheel. Now I’m dealing with a new issue. When the engine is warm, it won’t idle properly. The RPM drops too low and it stalls unless I keep giving it throttle.
          Still trying to figure this one out or find someone who can help dial it in.
          • Panici
            • Dec 2009
            • 2523
            There should be a coolant temperature VS idle valve position table.
            You will need to edit that.
