Miller W.A.R. Machine
  • digger
    • Nov 2005
    • 6196
    #286
    Originally posted by LowR3V'in
    wow man that seems extremely rich but if you dyned it.
    Is that for max power or some sort of safety net?
    not that rich really 12.5 to 13.5 is normal for peak power NA, small AFR changes have pretty small impact on power.
    If you hear knock you retard ignition timing
    • NC325iC
      • Mar 2004
      • 6565
      #287
      Recieved my PSIK and War chip yesterday, so i thought id give a quick install review.
      Ill start out with the particulars of my e30. it is an early model (86 e) with a late model stroker in it. I have also completed a e36 rack swap using the factory e30 high pres hose.
      so, install is pretty simple. The rubber elbow they have is a 3inch 90 degree piece, on the m20 throttle side it has a little insert to step it down the the right size (2.5"?) This little piece while effective is a bit of a PITA. it slides out fairly easily, it also adds about 1/4" length to the end of the elbow meaning that you dont get as much engagement with the actual elbow and the TB as you might like. When i put on the clamp i made sure to have it half and half on the elbow and the insert. Note 2 about the elbow, that rubber is really sticky, have some windex on hand to aid with installing it. The ICV in my case is in a really strange position, its pushed out enough that it is right on top of the dipstick, i can still remove the dipstick but just barely. Perhaps relocating the ICV and including a longer hose from ICV to TB would be better. Now the other end, the filter must be installed before you bolt up the tube, which is a bit annoying. Also i have to relocate my horn, which isn't a problem at all and it says that in the manual. On to the pictures. As youll see there is a bit of a problem with the early model filter location, which in dry weather it will certainly provide lots of free flowing air, if its raining there is nothing to block the rain from the filter.
      edit: forgot to mention that with the rack swap i have the HP hose turned around so the metal tube side is on the pump, in order to fit the intake i had to bend the metal tube on the HP line so its got about 1/4" of space between it and the intake.
      • Pedaaa
        • Jan 2011
        • 38
        #288
        Nice report and photos 8-)
        Have you already got some driving experience with it?
        Can you recommend this KIT?
        I am also thinking about purchasing a miller 3" MAF + War chip.
        But I don´t really like their 3" rubber elbow. So i am not really sure what to do...
        Maybe I´m going to use a 2,5" to 3" reducer elbow and make my own piping, similar to the Miller one.
        • NC325iC
          • Mar 2004
          • 6565
          #289
          unfortunately i havent driven it yet as my fuel pressure regulator has shit its pants and must be re sealed.
          • The Humjet
            • Jun 2010
            • 528
            #290
            Sorry to go sorta off topic here since this is most NA m20 territory here, but how do your W.A.R and Maf kits cope with forced induction. A lot of FI people always get a full standalone ECU but reading about your product including your turbo tuning package, I think that it would be enough for the kind of person who would be over the moon if his m20 can put down 300whp. It is such a more simpler alternative why do people cause themselves head aches wiring a full standalone?
            • LowR3V'in
              • 4209
              #291
              Because people like to know exactly what's going on with their engine :)
              The miller maf doesn't have a datalogger. You can't tune unless you're on a dyno or
              buy separate datalogger ($300 + sensors?)
              It's limited to specific injectors and
              allot of other good reasons why "people cause themselves head aches wiring a full standalone"
              • The Humjet
                • Jun 2010
                • 528
                #292
                thanks i think ill just get ms2, with the motronic conversion im doing apparently it's about 90% plug and play after that
                • handysmurf59
                  • 335
                  #293
                  Been running my Miller PSIK for the past month here in Paradise and loving it. On a stock m20b25 with <100k on the original motor. Any questions hit me up.
                  "But the way it deals with bumps and heaves makes you think the shocks are filled with unicorn farts and pixie tears."
                    • 34844
                    #294
                    More like 99.9% these days, talk to keith (whodwho) for an excellent kit.
                    • brody
                      • Jul 2009
                      • 334
                      #295
                      Well some more serious progress, the WAR Machine has grown an extra set of valves!
                      • digger
                        • Nov 2005
                        • 6196
                        #296
                        http://www.r3vlimited.com/board/showthread.php?t=212370
                        when are you guys realising the adapter for the M30 TB to fir the M20 intake manifold?
                        • LowR3V'in
                          • 4209
                          #297
                          What ever happened to this guy?
                          • Bavarian Performance
                            • Dec 2010
                            • 39
                            #298
                            Did you guys ever get any acceleration numbers; 0-60, quarter mile, before you swapped motors?
                            • TimR
                              • Mar 2008
                              • 549
                              #299
                              My M30 TB at 63mm works great on the M20, i also matched the TB to the manifold, 67mm. Stock M30 TB 63mm and it will port to a max of 66mm, Riot offers a 64.5mm M20 ported TB. The last attempt at an adapter for M30 to m20 manifold was $200 but they don't seem to be for sale. I can't believe with all the other cars that increase TB's E30 guys seem to not do it. Contact me for more info.
                              • MonkeyMan
                                • Jul 2011
                                • 426
                                #300
                                Brody, I'm getting ready to order the PSIK this week but had a question: are you able to tailor the supplied chip to my current setup? I know it's not going to be as precise as the WAR chip, but its worth a try before spending the extra money..
                                I'm running an '89 i motor with a 323i crank (10:1 comp, 2554cc) and 323i cam (more lump than stock).. its not so much the mild stroke increase that concerns me, but the increased c/r (and the crappy Cali 91 octane).. thanks for the help..
                                .. oh and +1 on the M30 TB adapter
                                Make the bastard chase you.
