LC-1 AFR reading problems.
  • ak-
    • 12422
    Problem fixed, pg. 3.
    Okay, I'm giving up and finally asking for help.
    Stuff:
    M20
    LC-1 6 wire, spliced into stock o2
    Megasquirt MS2
    Problem:
    AFR gauge will always peg at 22.2 AFR or 7.4 AFR depending how I switch the analog 1 or 2 wire/programming around with the engine running.
    Setup:
    I spliced in my LC-1 into the stock o2 sensor with the use of every diagram you could find on the net and still cannot get proper AFR readings.
    I have my LC-1 grounds (blue and white) and gauge grounded at the ECU ground (passenger shock tower).
    Analog 1 (brown wire / wideband) is spliced into the stock o2's signal wire (black)
    Analog 2 (yellow wire / narrow band) is spliced into the gauge's signal wire (white).
    Red wire is connected to my hazards light button, 12v switched with a fuse in between.
    Whether I use factory defaults on the controller, switch the analog outputs around so that analog 1 becomes 2 and analog 2 becomes 1, I still cannot get proper AFR readings. It will just stay pegged at 22.2AFR or 7.4AFR (Depends how I have the analog outputs switched) with the engine on and cruising.
    Notes:
    -Before megasquirt, I was using a separate bung for the LC-1 and it worked/read perfectly fine. If I remember correctly, both analog outputs were connected to the gauge's signal.
    -Tuner studio's AFR reading is in synchronization with my gauge, so I can assume my groundings are fine.
    Where did I go wrong?
    1991 325iS turbo
  • kistler#7
    • Jun 2013
    • 186
    What does it read in logworks?
    m20b27 Turbo. Hx35. Twinscroll Mani. MS1. 42lbers
    http://www.r3vlimited.com/board/showthread.php?t=338818
    • ak-
      • 12422
      I can't seem to get logworks to connect properly, but have to admit I haven't tried hard enough to see what's up with that. I've never used it to begin with.
      1991 325iS turbo
      • george graves
        • 20003
        I must really be missing something....ak - I know you know your stuff....
        Why are you hooking up a stock (narrowband o2 *sensor*) to a LC-1's input? I must be mis-reading something. Or the 5 hours of sleep I've had.
        Wideband controllers have have only one input (usually - unless you buy the super special model and then you know what you are doing - so assume one input) . And one or more outputs(almost always 2). The input is the sensor you install in your down (exhaust)pipe. The outputs (usually two) will come pre-programmed with one channel being a 0-5 output for a wideband signal. And the other is usually programmed to do a "fake" (and usually half ass'ed) narrow band 0-1v output.
        I
        Originally posted by Matt-B
        • ak-
          • 12422
          Why are you hooking up a stock (narrowband o2 *sensor*) to a LC-1's input for a wideband? I ust be mis-reading something. Or the 5 hours of sleep I've had.
          I'm just using the old o2 sensor's wiring harness/o2 connector (is this the proper term?) for the LC-1 to splice into. The LC-1 already has it's own wideband o2 sensor bunged into my downpipe.
          1991 325iS turbo
          • george graves
            • 20003
            http://www.megasquirt.325ix.com/MS_t...to_E30_O2.html
            I'll let someone else chime in. But Doesn't your WB o2 sensor plug right into your LC1? Why the splicing?
            Down pipe---bung---sensor---sensor harness====(plugs into)====LC-1 connector----lc-1----(Then off to a gauge/megasquirt/etc)
            • ak-
              • 12422
              Yes the WB o2 plugs directly into the LC-1 controller, but there are wires that come out of that need an analog output, +12v, and ground. People usually wire that into the stock e30 o2 connector.
              1991 325iS turbo
              • ak-
                • 12422
                Halp. I kind of just want to be told it's broken so I don't have to worry about it anymore.
                1991 325iS turbo
                • Northern
                  I like cupcakes & sh!tboxes
                  • 5278
                  If you lived nearby you could borrow one of mine to test, but that's a bit of a trip.
                  Originally posted by priapism
                  Originally posted by shameson
                  • ForcedFirebird
                    • Feb 2007
                    • 8300
                    When you open logworks, are you using the "connect" button, then selecting the correct virtual com port?
                    john@m20guru.com
                    Links:
                    • ak-
                      • 12422
                      That's awfully kind, thank you
                      I hit connect and a pop-up told me it can't locate something-something. It was 1am and it was my first time dealing with logworks, so I just left it alone and tried trouble shooting other things.
                      What should I be looking for in Logworks once I get it working?
                      1991 325iS turbo
                      • ak-
                        • 12422
                        After talking to my tuner. The dude says that regardless of how I wire the rest of the stuff, I should still be seeing a proper AFR reading on the gauge as long as I have the write signal wire going to my o2 harness sensor (the signal wire of the 4 on the stock o2 connector).
                        I know I have the write wire wired in, so does this mean I have a faulty wideband?
                        1991 325iS turbo
                        • redsubdivisions
                          • Feb 2011
                          • 1762
                          I have an LC-2, and from what I have heard, it is merely 2 wires less than the LC-1. If I were you, I would bust out that test light or a multimeter and check to see if your power wire for the sensor itself is getting power. Mine wasn't and I just re-routed it to a switched power source.
                          1989 325i - 2.7i, Holset H1C, 60lb injectors, whodwho MS-PNP.
                          2012 Passat TDI - DD Duty
                          2008 GMC Yukon XL Denali - Kiddie hauler/grocery getter
                          • ak-
                            • 12422
                            I did just that and I am getting power. I have my switched 12v from the defroster.
                            I re-checked my wiring again and again.
                            My sensor is brand new, I don't know why it would go bad. Anyone have a controller I could borrow to test? :/
                            1991 325iS turbo
                              • 34844
                              Are you running a stock computer or standalone?
