M42 turbo fact thread
  • MF DOOM
    • Apr 2012
    • 944
    #46
    they would love each other. if i dont go the borgwarner route ill go gtx3071.
    drunk post tho
    • PFCRayB
      • Nov 2009
      • 403
      #47
      Well im out of the turbo m42 for now...long story.....so im selling my mani, intercooler, and the intercooler piping for 150. Ill have pics monday or tuesday
      Originally posted by Erick
      Dude the M30 is stupid simple design. It's 6 manly men inside the block pushing up and down on the cylinder with Hercules-like force.
      • Damon in STL
        • Jun 2013
        • 5
        #48
        I'm interested.....and will buy after I see what is included in pics.
        Damon in STL
        • willworkfore30s
          • Aug 2011
          • 1090
          #49
          I'm interested as well
          • MF DOOM
            • Apr 2012
            • 944
            #50
            What manifold is it?
            drunk post tho
            Yeah.. Ak, stock motor? how much boost?
            • MF DOOM
              • Apr 2012
              • 944
              #51
              What rear end are you guys using? think i might trade for a 3.73. I got a 2.93 for when I planned on driving to ca but the cars kind of a slug off the line now.
              • Dj Buttchug
                • Jun 2010
                • 7654
                #52
                im running a 3.73 now. its great but a little short imo. Waiting on my 3.46 to get here from a member. will report back with details.
                2.93 is to tall. it takes to long to get into boost. Thats why I bailed mine. For the freeway tho its still nice.
                Turbo M42 Build Thread :Here
                Ig:ryno_pzk
                I like the tuna here.
                Originally posted by lambo
                • MF DOOM
                  • Apr 2012
                  • 944
                  #53
                  so... guess who put their clutch on backwards.
                  at least i found my issue..
                  also discovered its a 240mm clutch. thought it was a 228
                  • e30guydownunder
                    • Jul 2008
                    • 874
                    #54
                    Simple solution is always good :)
                    I'm swapping to a 3.73 or 3.64 (currently run a 4.27) as apparently the motor / turbo combo runs out of legs at Bathurst on the SHORT straight :) Straight at Eastern Creek is pretty long too and if I can hold 4th at Wakefield will be a bit better overall.
                    - Chris
                    Project M42 - 255 @ 19 psi
                    • wazzu70
                      • Jan 2005
                      • 1143
                      #55
                      That will cause some problems! :)
                      -Nick
                      M42 on VEMS
                      • MF DOOM
                        • Apr 2012
                        • 944
                        #56
                        In my defense neither side was stamped "flywheel side" and thats how they shipped it to me.. But its driving now :)
                        • PFCRayB
                          • Nov 2009
                          • 403
                          #57
                          If anyone wants to see the parts I have pm me your number and ill text you the pic
                          • MF DOOM
                            • Apr 2012
                            • 944
                            #58
                            I have to ask what you want for that manifold?
                            • benjami
                              • Jun 2013
                              • 3
                              #59
                              Iv been planning on building my m42 into a turbo for some time now.
                              so far>
                              TD06sl2 with 8cm t3 v-band turbine
                              44mm external wastegate
                              1 1/4 steam pipe manifold
                              plans are probably 8psi as its a daily driver, still need to finish manifold for the wastegate
                              Thanks for the influence chris :)
                              • e30guydownunder
                                • Jul 2008
                                • 874
                                #60
                                No problem, good to see you are still going ahead with yours. I strayed.....but I'm back in a big way. Manifold looks like it has come out great! Very compact. I had to go with a different design to get the turbo to fit.
                                I've just finished prepping the block. Was previous drilled and tapped to M12 studs (out of an M30) but these had been over torqued. I have drilled and tapped the block to take oversize M12 rolled threaded inserts. This is stronger again than the M12 studs. You can also see the O-Ring setup for the copper head gasket:
                                - Chris
