hi to all fellow m42 e30 owners. i got a question to u who had gone through the process of rebuild. i'm following bentleys manual and i cant locate where does a part numb 1111 1734667 go.it's a non return valve and it should go together with a spacer numb 1111 1739185. bentley says it goes in the hole in the block but it cant fit there. i wonder if anyone knows the solution
M42 turbo fact thread
They never make it simple do they? Too bad they arent interchangable.
I would be curious to know which heads got the smaller lifters!-Nick
M42 on VEMSComment
E36 heads have 6mm valve stems 'v' the E30 heads which are 7mm, maybe this is just some confusion between valve stem size and lifter size. This is the first time I'd heard for there being different sized lifters between the two.Comment
So if you were looking to build a reliable m42 turbo to make 200-250whp, what components would you use to do it. Say you were budget minded but wanted to do it right.sigpicComment
Head studs and a fresh gasket. Standalone ecu.
As long as the tune is spot on you shouldn't have an issue with stock compression or pistons. What will become an issue is when you wan to turn it up more :)Comment
I was thinking about getting a little more in depth than head studs and a tune. I was looking at a budget of around $3k including an engine refresh. I'd really like to be closer to the 250 whp range.
I want something that won't have me thinking I should have just thrown in an s52 and called it a day.sigpicComment
What do you mean more in depth? You can rebuild the bottom end if you want to factory spec if you are budget minded. If you want to spend some coin just because you should first spend on lower compression pistons, and then upgraded rods if you really want to.I was thinking about getting a little more in depth than head studs and a tune. I was looking at a budget of around $3k including an engine refresh. I'd really like to be closer to the 250 whp range.
No amount of engine building can save you from a crappy tune. For whatever reason people seem to overlook that and think some magic array of parts will protect from a poor tune. This is not the case.
Getting a quality turbo is one of the best places to spend your money. Youll get so much more out of this than buying needless engine internals.-Nick
M42 on VEMSComment
I have no problem using the stock internals as long as they will reliably hold up to my power goals assuming I have a good tune.
The motor I want to use has around 160k on it but I ran it very low oil a while back because I didn't get the oil canister lid sealed on very well. Now it is eating some oil but seems to run fine. Have taken it on a couple 4+ hr trips since then and drive it almost every day.
I thought I would tear it down and possibly get it re-honed with new rings. Maybe o-ring the block and get the head refreshed. I was planning to looking to upgrades to things like the valves and lifters. I am at the beginning of my research for this project.
I don't have it all figured out yet. I just know I want around 250 reliable hp and I want to learn about turbo's. The less money it takes to get there, the better but I'd like to stay under $3k if possible. I like the kit that was linked but would like a little more power and the manifold seems a bit restrictive with those t's.sigpicComment
You can easily hit that power level on stock internals, although replacing the bearings, rings, and giving it a hone is an excellent idea. Thats basically what I did on mine.
I agree the manifold with Jakes kit leaves a lot to be desired. I would much prefer to use one from Otis (Good&Tight).
Upgrading the valves and lifters will not be a good bang for the buck honestly. Put that money into engine management, turbo & tune to get the best results.-Nick
M42 on VEMSComment
What would you suggest for engine management? Standalone can get expensive quick it seems.sigpicComment
