Bliks Supa Chaga Build
  • kamotors
    • Nov 2007
    • 7102
    #61
    Originally posted by tinkwithanr
    Really? I'm getting 5.6 psi before subtracting the overlap allowance.
    Boost (psi) = (PR x 14.7 x V / C/2 ) - 14.7 - I
    PR = 4.75 in / 2.795 in = 1.699
    V = 62 in^3 (Eaton M62)
    C/2 = 2.5L/2 = 1250 cc = 76.27 in^3
    Boost = (1.699 x 14.7 x 62 / 76.27) - 14.7 = ~5.6 psi
    This seems more in the ballpark just because the stock crank pulley is probably close (possibly a little smaller, but not drastically) to the original diameter of what drove the charger in it's original application.
    hes running an eaton m45 not m62 like the thread shows, but my math is still probably off. and I also seemed to of forgotten to convert cc to in^3
    but i'm still getting extremely low boost like less than 1 psi.
    so that's good news in a way you only need about an 8" pulley on the crank to get about 10psi
    7speedshop.com
    • TheBlik
      • Nov 2011
      • 150
      #62
      I think i should go big or go home with a 12'' pulley :)
      sigpicDiRTYE30-RALLYE30
      • kamotors
        • Nov 2007
        • 7102
        #63
        do it
        7speedshop.com
        • e30leigh
          • Mar 2012
          • 481
          #64
          i think you should be talking to that denny dude. i dont know much about superchargers. i know how they function. but i dont know what they need to function correctly.
          ie i had no idea the TB needs to be before the charger.... id be pm'ing him dude.
          he seems in the know. even if he had a bit of a rant there
          • TheBlik
            • Nov 2011
            • 150
            #65
            Hahahaha well really, i dont give a hoot, i know i messed up big time. That's reality, he did it his way and im doing it my way. Everyone has their choices. Anyways i have my surgery coming up so i cant really be spending money, and after that i have four to six weeks of recovery and physical therapy, so ill have a lot of time to research and make corrections. probably thinking of getting a 8'' or a 12" pulley make as much boost as possible but its still in the air, i do not want to give up on this build, i want to twin charge so here is step one.
            • TheBlik
              • Nov 2011
              • 150
              #66
              would anyone know a CNC guy that can do 3D? The guy i know can only 2D junk. and really i just need the pulley and i will be boosted :) Maybe ill pull out the DIRTY-E30 today get some pics and a video of what it sounds like.
              • kamotors
                • Nov 2007
                • 7102
                #67
                maybe contact these guys? maybe you could get a smaller pulley weld-on/press fit for the charger
                The powerful shopping cart software for web stores and e-commerce enabled stores is based on PHP8 with SQL database with highly configurable implementation based on templates
                7speedshop.com
                • TheBlik
                  • Nov 2011
                  • 150
                  #68
                  wait maybe i should cut off the pulley from the blower and weld on a bigger one! yeah thanks Kamotors!
                  • kamotors
                    • Nov 2007
                    • 7102
                    #69
                    ... but you need a smaller blower pulley I thought?
                    7speedshop.com
                    • TheBlik
                      • Nov 2011
                      • 150
                      #70
                      erggg, why dont i just get an m90 ;)
                      • TheBlik
                        • Nov 2011
                        • 150
                        #71
                        bump. so, im really not sure at this point on what to do. m90 is 3.25 in longer than the m45. so no room at all, where i had it mounted and if i did it denny's way, where it is on the alternator side, i may be able to fit it. or i could get an m62 with the electric clutch, and maybe still have the same out come as the m45, which would be a waste of time. I DID RESEARCH DENNY!!! woah weird. Plus the m62 is for a 3.0 to 5.0 liter motor so if it did work i might be putting out some real good boost. anyways should i keep wasting my time on this or turbo?
                        • unevolved
                          • Nov 2011
                          • 714
                          #72
                          Keep pushing through. Innovate.
                          1991 318i SOLD
                          2003 325i SOLD
                          Racecars and stuff.
                          • kamotors
                            • Nov 2007
                            • 7102
                            #73
                            an M62 will get you roughly 5 psi on the stock M50 crank pulley, it would be fun but power is addicting and you cant just turn a nob and get more boost with a supercharger you would need expensive pulley swaps every time you wanted more power..
                            buuuut.....if your going to supercharge I think the clutched M62 supercharger is the way to go.
                            7speedshop.com
                            • TheBlik
                              • Nov 2011
                              • 150
                              #74
                              yeah im thinking that why should i have boost at idle. clutches are cool. so 5 psi would be super awesome.
                              • TheBlik
                                • Nov 2011
                                • 150
                                #75
                                Still trying to sell the M45. Not going so well. Had my knee surgery, very achy, staples out today. Gonna sneak into the garage, and disassemble super charger junk, make it Not/Awesome, haha, get it smogged and drive around, once i get my MAF back of course.
