A/W Intercooler using a radiator from an auto
  • 2mAn
    Señior Mod
    • 20724
    Just had a weird idea...
    If you were to use an air-water intercooler on a turbocharged car, is it possible to use the automatic transmission cooler?
    I hope that makes sense
    Simon
    Current Cars:
    -1966 Lotus Elan
    -1986 German Car
    -2006 Volkswagen Jetta TDI
    Make R3V Great Again -2020
  • Sonny
    • Feb 2019
    • 100
    I think it should work, they should both be the same design wise. Attach a fan to it to.
    • 2mAn
      Señior Mod
      • 20724
      anyone with knowledge that can help is appreciated
      Simon
      Current Cars:
      -1966 Lotus Elan
      -1986 German Car
      • Sonny
        • Feb 2019
        • 100
        sorry
        • varg
          Florida Turbo Man
          • May 2014
          • 3400
          The automatic transmission cooler, as in the little loop in the radiator of an auto car? That's the only transmission cooler I'm aware of in E30s. It would be pretty terrible, the engine coolant is about 100 degrees hotter than you would want your intercooler coolant to be and even if the engine coolant was 80 degrees or so you wouldn't be able to dissipate much heat from the intercooler's water circuit with such a small heat exchanger, so the system would heat soak quickly.
          IG @turbovarg
          '91 318is, M20 turbo
          • e30davie
            • Apr 2016
            • 1788
            Sure you can use it, but it would be called an "interheater" when its done.
            (Assume you are talking about the auto cooler that is integrated into the coolant radiator)
