A/W Intercooler using a radiator from an auto
    Just had a weird idea...
    If you were to use an air-water intercooler on a turbocharged car, is it possible to use the automatic transmission cooler?
    I hope that makes sense
    Simon
    Current Cars:
    -1986 BMW 325e & 1968 Datsun Roadster 2000
    Previous Car Count : 21 ... and climbing...
    Originally posted by Melon
    Let it be known to all. Simon fucking keeps it real.
    I think it should work, they should both be the same design wise. Attach a fan to it to.
      anyone with knowledge that can help is appreciated
      Simon
      Current Cars:
        sorry
          The automatic transmission cooler, as in the little loop in the radiator of an auto car? That's the only transmission cooler I'm aware of in E30s. It would be pretty terrible, the engine coolant is about 100 degrees hotter than you would want your intercooler coolant to be and even if the engine coolant was 80 degrees or so you wouldn't be able to dissipate much heat from the intercooler's water circuit with such a small heat exchanger, so the system would heat soak quickly.
          @turbovarg
          '91 318is, M20B25, T3/T04E 60 trim (15psi), megasquirt, coilovers, Z3 rack, cold AC
          [b u i l d]
          [Car of the month: April 2018]
          0c8b7c9527af628a346878feb14bf757
            Sure you can use it, but it would be called an "interheater" when its done.
            (Assume you are talking about the auto cooler that is integrated into the coolant radiator)
