Rocker Arm shaft stuck
  • Quackity
    • Aug 2021
    • 6
    Disassembling a 2.7 head and trying to get the rocker arm shafts out but they are not budging. Got them about 1 inch out and now no matter how hard I whack them they wont budge. There is no tension on any of the rockers, it seems like there is some dirt binding it up but not sure it would cause 0 movement.
  • 82eye
    • Jan 2009
    • 2097
    you can use a socket extension as a drift. the rockers from cyl 1 are removed first. how to strip an m20 head.
    • Quackity
      • Aug 2021
      • 6
      I am using an extension my problem is that its not moving.
      • digger
        • Nov 2005
        • 6192
        probably a burr, score,, build up or the end is mushroomed . need go back a bit and inspect for damage. if you keep pounding it something will break
          • 34844
          have you removed spring tension from all the rockers? if there are any pressing on the face of a cam lobe, it's going to be tough to get out.
          there's really no reason to use a hammer on them. that's why a lot of them end up messed up..
          • Quackity
            • Aug 2021
            • 6
            No tension on any of the rockers, I tried pushing it the other direction and it wont move at all.
            • 82eye
              • Jan 2009
              • 2097
              do have a pic ?
              check to make sure you didn't have a rocker walk off the cam lobe. it happened to me on reinstall.
              • Northern
                I like cupcakes & sh!tboxes
                • 5281
                How clean is the rocker shaft? Oil varnish buildup is enough to cause issues
                Originally posted by priapism
                Originally posted by shameson
                • Quackity
                  • Aug 2021
                  • 6
                  Got the intake side out with a lot of cleaning and tapping, however the exhaust side is nearly completely stuck. I'm gonna replace it now but I cant get it out. Using a clamp to try and push it back in didn't work no amount of whacking will make it move.
                  • e30vert
                    • Jan 2005
                    • 1789
                    Your going to have to heat the rockers with a torch so they expand.
                    • ADEN
                      • 620
                      I had a terrible time with these shafts, i got one rocker free rotate the cam tried to hammer the shaft out another one returned to place and jam the shaft again.
                      • Vincenze
                        • Apr 2019
                        • 1036
                        You can file the ends of the shafts. They can be mushroomed after hammering on the ends.
                        You can easily score rocker arm inner bearing surfaces.
                        • Quackity
                          • Aug 2021
                          • 6
                          Got it out with a lot of heat and beating. Think I can reuse this rocker shaft with some filing as suggested earlier? Thanks all for the help
