m20 2.8L “Stroker” build assistance.
  • Mygtaboy
    • Oct 2025
    • 1
    Good afternoon, first time using the forums here.
    I’m hoping to get some assistance or pointed into the right direction on completing a 2.8L “stroker” build utilizing an m50/m52 crankshaft and some assistance from this write up here; https://www.e30zone.net/e30wiki/inde...Building_a_2.8
    Have never pulled a motor out, have never done anything with an engine apart from removing the head once.
    goal of the project is to have a nice daily driver with a little bit more power.
    looking for general tips or advice on what to look out for when rebuilding a motor like this as well as what parts will be needing replacing.
  • digger
    • Nov 2005
    • 6171
    you need to be more specific.
    first thing you need the parts
    • M52b28 crankshaft ideally the small counterweight version,
    • eta 130mm rods
    • M20b25 pistons (short skirt version ideally)
    • oil seal sleeve
    • M5x 18mm crank bolt and modified washer
    • DesertBMW
      • Aug 2011
      • 1038
      You never pulled the engine in your life and you talking all of that engine building? Fix it all stock, problem solved.
      • It's Soda Not Pop
        • Jan 2022
        • 877
        sometimes we have to dive head first to learn anything. I say do it. Especially if he is willing to get in there and get dirty. Hell I've learned by diving in when I was new to cars.
        That being said I understand your point as well.
        88' Seta 2.7i Zinno
        https://www.r3vlimited.com/board/for...430-my-88-seta
        • McGyver
          • 4637
          My advice is to find a cheap engine to machine and build while you keep your car running, then swap it over.
          It keeps your car on the road and usable, it eliminates the potential stress of needing to move a dead car, gives you time to go at your pace instead of having a tight timeline, and the swap happens at once so you remember how it goes back together.
          • jpgroth
            • Jun 2018
            • 3
            Noob bump here. Any easy way to identify the small counterweight crank? I'm going to look at a M20 block and M52B28 rotating assembly on marketplace.
            • hasa
              • May 2013
              • 307
              Big counterweight version has the tone ring for crank position sensor. It does not turn in M20 block.
              • digger
                • Nov 2005
                • 6171
                • zaq123
                  • Jul 2016
                  • 1559
                  using stock or custom pistons? Bigger CCW crank is superior and worth clearancing he block which is super easy, Custom pistons is a good idea anyway. Not even gonna mention that big CWW crank is sooo much easier to find
                  • digger
                    • Nov 2005
                    • 6171
                    Small counterweight is a Euro thing from e36 328i. If you are in the USA probably wont find one
