1986 M20b25 into 1990 325ix
  • rtkelly32
    • Nov 2025
    • 1
    Hi guys, I have a 1990 325ix with a blown motor. currently looking at a good deal on a 1986 m20b25 out of a 325ix. I’m seeing most of everything is adaptable onto the head and block, but wondering if there are any issues I’ll run into with the drivetrain and ecu.
  • TobyB
    • 5296
    As long as it's not an eta and you change things such as sensors, oil pan and the thermostat housing, it ought to work just fine...
    www.realoem.com has part numbers broken out, if you want to go through it carefully.
    t
    • litu
      • 848
      That info what you are giving, it is bolt on job...When you have old engine out and you have "new" engine by side you can see what need to take your current engine to that "new" engine...
      It looks like that your current engine is Motronic 1.3 ECU system and "new" engine is -86 so it should be Motronic 1 ECU system, so i would take from your current engine, water pump/belt pulley, harmonic balancer, crank shaft position sensor/holder, oil level sensor, engine wire harness.
      https://www.facebook.com/Cry_77_IX-110483784967661
      https://www.instagram.com/cry_77_ix/
      • Northern
        I like cupcakes & sh!tboxes
        • 5284
        Intermediate shaft/oil pump should be different/spin the other way. Oil pressure relief also likely different. Might need an extra hole drilled for oil pan (or plugged/ignored, I can't remember which way.
        Not sure the best route for what to change over as far as the above.
        I would run all the '90 ix electronics, I think there are ABS differences that may be tied into the ECU?
        I haven't owned an ix in 10 years so I'm rusty.
        Originally posted by priapism
        Originally posted by shameson
        • TobyB
          • 5296
          Do tell more. I've only dealt with the M10 1980 direction change- didn't have a clue that the M20 also changed...
          t
          • Northern
            • 5284
            From a few sources:
            Originally posted by nando
            the ix uses a different oil pump and intermediate shaft gear. you'll have to remove the oil pressure regulator from the RWD block. there's nowhere to put a dipstick for the ix.
            best bet - remove the internals from your RWD block, put them in an ix block.
            Originally posted by 77320i
            For us ix people though the oil dipstick is in a different place, the oil pickup is at the back and not the front, and the intermediate shaft that drives the oil pump is geared different and spins backwards (WTF why? Can someone explain?) so realistically, the best option is to swap in 1988 SETA pistons, rods and the crank.
            • litu
              • 848
              But that dude who was post this topic has luck, when both engines are from e30 ix, current is with FL motronic 1.3 system and "new" is from PFL motronic 1
              • digger
                • Nov 2005
                • 6198
                t
                The intermediate shaft doesn't reverse but the oil pump and the shaft runs the opposite direction because the gear on the intermediate shaft is different.
                • Northern
                  • 5284
                  Completely missed that they were both ix. Rare situation haha
                  • TobyB
                    • 5296
                    BMW... go figure. I never would have guessed....
                    t
                      • 34844
                      the intermediate shaft must be switched, or you will not get any oil pressure.
                      also the oil galleys for the ix pump are different, I'm still not 100% sure the pump will bolt to the non-ix block and work correctly.
                      you will want to keep the original ix electronics, the ABS tie in to the ECU is extremely primitive but it is still important to the correct function of the ABS system.
