Waterpump Recommend?
  • 82eye
    • Jan 2009
    • 2020
    what is the word on m20 water pump brands these days? i've been chasing a coolant issue from day one after my rebuild. narrowed it, we hope, to a faulty waterpump. i've less than a thousand klicks on the thing, and want to replace it with a quality brand.
    i notice graf is available, they used to have a decent reputation. bmw brand is available but i'd like to duck the oem tax if possible.
    if the pump doesn't fix it the last thing left is the radiator.
  • litu
    • 837
    I have lost two Graf water pumps in one years, first one was bearing issue(maybe water pump belt was little too tight, cannot way 100% sure, i was checking it should not be), then this second was staring leak from gasket(not sure why), now this 3 Graf is in place, lets see what will happen..Next is coming Meyle branded waterpump
    https://www.facebook.com/Cry_77_IX-110483784967661
    https://www.instagram.com/cry_77_ix/
    • digger
      • Nov 2005
      • 6121
      The answer is self evident
      • 82eye
        • Jan 2009
        • 2020
        so far the graf seems the most used. hepu also rates but is close to twice the price. rein from fcp euro also gets mentioned. the bmw pump is over $400 here with shipping so not an option at all.
        edit: after wading through piles of threads i ordered a graf with the metal impeller. local indie shop also recommended graf or hepu.
        • 82eye
          • Jan 2009
          • 2020
          odd, my edit didn't show up in the last post.
          wound up ordering a graf yesterday after talking to my local indie. they recommend either graf or hepu. of course that's before i saw the first reply. the hepu is about double the cost of the graf, but may have been worth it. the next one will be hepu if this one fails.
          pretty sure the last was a rein with plastic impeller. it came packaged with a gates blue belt i had ordered, i think they used rein in the timing kits.
          • digger
            • Nov 2005
            • 6121
            on an expensive well maintained engine go for the OE, for a budget engine the HEPU is a more budget option that isnt rubbish
            • Vincenze
              • Apr 2019
              • 1013
              The pump that BMW sells was refurbished after it had failed.
              • zaq123
                • Jul 2016
                • 1514
                Pretty sure GRAF is OEM supplier. edit: Nope, apparently Saleri is OEM
                • McGyver
                  • 4624
                  I've had several grafs fail, i think hepu is better, but i still used graf last time because it's cheaper and i didn't expect to need more than a few months out of it.
                  • MrBurgundy
                    R3V Degenerate
                    • Mar 2012
                    • 5548
                    I use saleri
                    42 bucks
                    oem
                    • 82eye
                      • Jan 2009
                      • 2020
                      i won't be too thrilled if the graf fails early. the local shop told me pumps of all brands including oem have failed in a yr or less. there was a serious dive in quality across them all that began almost a decade ago and inceased exponentially in the last 5 yrs. they have had a lot of issues with front end components failing over the same time.
                      • digger
                        • Nov 2005
                        • 6121
                        GEBA looks closest to OE
                        • Maybe Magpie
                          • Apr 2020
                          • 127
                          GEBA GEB-580 is made in Germany, as of writing Graf's and HEPU's are both made in Italy (and I'd wager both of those at the same factory as each other). I got a GEBA myself for when I do my timing belt and pump, it has a metal impeller versus the others' plastic. I can't necessarily attest to GEBA's longevity yet, but it looks like the stoutest of the non-PRC-made options.
                          i'm in love with german cars // gliding past me on the autobahn
                          stainless idols with silent hearts // never turning as we drift apart
