M20 dyno results
  • zaq123
    • Jul 2016
    • 1574
    M20 dyno results
    Just dyno'd this 2.9L 10:1 with Schrick 284/272, ITBs and completely original AMC head with Supertech valves and OEM springs/rockers. 93 octane (98 ron) gas.
    Low numbers in the timing table (down low) is the max it wanted to handle without knock. No knock up top and the timing represents where MBT is.
    I know AMC head isn't ideal. But my freshly rebuilt 885 had a crack and I just wanted to enjoy this car already hence was like F' IT and bolted AMC head to it. Have new 885 and maybe will drop it off to be machined and bolt it over the winter.
    What's your thoughts on this timing and dyno?
    Click image for larger version  Name:	IMG_4031.jpg Views:	0 Size:	256.8 KB ID:	10165488 Click image for larger version  Name:	IMG_4026 2.jpg Views:	0 Size:	166.4 KB ID:	10165489
  • digger
    • Nov 2005
    • 6215
    I’d be looking at the cam timing with adjustable cam gear as a couple of members either here or old e30tech forum found a bunch retarding the cam . The cylinder head is definitely not ideal and likely restricting things somewhat.
    • DesertBMW
      • Aug 2011
      • 1043
      first why even waste all that time and money on M20 just to have the same power as bone stock M52B28? It is well known that M20 has poor chamber design, that is why the engine stock comes with 9.3:1 compression ratio, and then even with that it will knock on hot day.
      If your project is limited with knock with 93 octane. I would try some 117vp racing fuel, just to see what can your engine do with that.
      • zaq123
        • Jul 2016
        • 1574
        cam was set to Schrik Spec with adj. cam gear, 4deg. retarded.
        • zaq123
          • Jul 2016
          • 1574
          M52B28 is 193HP. This Dyno is more on par with N52B30, 231HP (196WHP with ~15% loss for the drivetrain). 60HP gain from stock M20B25( about 35% jump) is not exactly WAR chip kind of mod.
          • AWDBOB
            hooptie connoisseur
            • Aug 2013
            • 4516
            This is too funny- I've known KP since like 2008 lol. He sent me a pic of your car on the dyno!
            Jak Stoll in Louisville had issues with his AMC head. The chambers were smaller than a genuine 885 and they varied by up to 4cc due to poor machining.
            Cinnabar325is owns Mission Motorwerks in Bechtelsville and might be able to get the head right
            • 88Sedan
              • Apr 2023
              • 282
              Results are not bad. I wonder if there would be more area under the curve w/slightly less duration on the cam. With the amc head on it might be more optimized since max head flow would be less than an 885. 200 whp sounds fun though.
              • MrBurgundy
                R3V Degenerate
                • Mar 2012
                • 5616
                lol people who come in just shit on other people are truly insufferable.
                first, this m20 is making more horsepower than a stock m52.
                secondly, m20s sound way better
                third, its the original or at least, period correct motor.
                24v swapped cars are played out and nothing exciting, especially a m52 swap.
                an almost 200whp m20 is fucking cool.
                • digger
                  • Nov 2005
                  • 6215
                  the power numbers are pretty good.
                  If you are confident the cam is dialed in to spec then it’s likely the head that’s holding you back a bit. The un modified amc is rough on the chamber and ports. I seem to recall it flows like 15cfm less than the 885 bmw casting and the shape is rubbish but I don’t know where I saw that. I haven’t cc the stock amc but as above the variation in cc seems plausible
                  What was piston to head clearance ?
                  • zaq123
                    • Jul 2016
                    • 1574
                    haha, this is awesome. Karl was like "what is Alpina?" . Unfortunately my 885 head was machined, 3 angle valve job done all that but was never pressure tested by the shop before all that work. It had a small bubbling invisible crack in the usual spot. I sourced new (to me) 885 head ready to go but was itching to drive this car this summer hence AMC on it now. Pressure tested new 885 head myself and it's ready to go. Unfortunately machine shop lead times are months, KP dyno appointment took me a month from when I booked it as well. So I had it road tuned and had KP to fine tune it for me. Once this winter is here, thinking about swapping the head but for now, it's what it is I guess and there is definitely plenty of power to have fun with it.
                    • zaq123
                      • Jul 2016
                      • 1574
                      just over 0.9 mm smallest clearance to just over 1mm largest (measured different from cyl to cyl). I'm not sure what those small dips are near peak on the dyno, tuner din't mention it nor I've seen his log. Wonder if it's knock threshold he set in Haltech he set pulled the timing away.
                      • zaq123
                        • Jul 2016
                        • 1574
                        Ok it was a long late day when she was on the dyno so I misunderstood the tuner at the time. I tried to edit first post but the forum is acting up again.
                        So this engine isn't knock limited, only down low hence lower timing numbers there. Sorry for the confusion everyone. I definitely think the head chocks this engine and it's going to be my next step.
                        • 2mAn
                          Señior Mod
                          • 21093
                          Numbers do feel a little low... yes different dyno and different day, but mine made very similar power on a "2.8L" setup with an unknown cam and an extrude-honed stock intake manifold.
                          I'm eager to add ITBs, but overall the car should be a hoot, I know mine is...
                          Simon
                          Current Cars:
                          -1966 Blue Boat
                          -1969 Red VW
                          -1986 White BMW
                          -2006 Green Thing
                          Make R3V Great Again -2020
                          • zaq123
                            • Jul 2016
                            • 1574
                            do you still have that graph?
                            • 2mAn
                              Señior Mod
                              • 21093
                              Post 170 here
                              Simon
                              Current Cars:
                              -1966 Blue Boat
                              -1969 Red VW
                              -1986 White BMW
                              -2006 Green Thing
