ZDDP Oil Additives
  • priapism
    • 1182
    I have three bottles of the stuff sitting in my garage and haven't touched 'em.
    -Sean : 91 Calypso 325i : Castro Motorsports SoCal Spec E30 #33
    • ForcedFirebird
      • Feb 2007
      • 8300
      Rislone
      john@m20guru.com
      Links:
      • TobyB
        • 5298
        You only have to wipe one cam to get jumpy about this-
        it makes a MESS out of what used to be a nice $6000 race motor...
        and yes, it comes up a lot.
        t
        • stamar
          • Apr 2011
          • 1362
          isnt the standard stp additiver zddp?
          that can be real cheap
          i mean it feels half retarded to use full synthetic and the 1.50 oil additive. but i think thats what the data says.
          believe it or not zddp means cheap the reason good oil doesnt have it is they use better stuff.
          • TobyB
            • 5298
            not.
            zddp is used to reduce the effects of sliding friction, specifically anymore just for cams.
            And most modern engines have roller rockers, so they don't need much of it.
            M20s have sliders. And do, under certain conditions.
            The reason that levels keep going down is that it shortens the life of a catalytic converter.
            t
            • ForcedFirebird
              • Feb 2007
              • 8300
              Originally posted by TobyB
              not.
              t
              Yup, it was eliminated for emissions, just like the tolerances on newer motors are tighter, requiring thinner oils. A lot of mfgr's use oil as thin as 0w-20.
              john@m20guru.com
              Links:
                • 34847
                huh? where did you pull this nonsense from?
                the reason they don't have as much is because the EPA limits its use to protect emissions equipment. ZDDP is still the most effective anti-wear additive. Don't expect a 2012 engine to last for 200,000 miles with no wear, though..
                • dnguyen1963
                  • Nov 2011
                  • 2651
                  Yes, degradation products from ZDDP bind palladium metal in the cat and eventually kill off the cat converter; thus the name "poison".
                  • priapism
                    • 1182
                    t
                    How so?
                      • 34847
                      well, according to the EPA - it's up for debate whether that's actually the cause. it's not set in stone that ZDDP damages cats. Look how long E30 cats last, and they used ZDDP for decades.
                      • FLG
                        • Sep 2011
                        • 3165
                        Guys we covered this in detail over on the charger forums
                        Some guys even had testing done.
                        The conclusion is any hi-po oil (amsoil, joe Gibbs..etc) have adequate amounts of zinc.
                        Rotella no longer has a lot of zinc in there new (well a bit old now) formula.
                        If youn want to use an off the shelf oil you could buy zinc additive from any speed shop or your local GM dealership.
                        Sent from my Galaxy Nexus using Tapatalk
                        -Build http://www.r3vlimited.com/board/showthread.php?t=295277
                        • chadthestampede
                          • Jul 2008
                          • 3601
                          Good read on oil:
                          Originally posted by LJ851
                          Feedback
                          • TrentW
                            • 2815
                            Originally posted by ForcedFirebird
                            This.
                            I use additive with conventional/low zinc synthetics, none with Mobil1 or Rotella. If a customer is partial to a specific oil, then I add the ZDDP since in the end, I am responsible for their vehicle. More ZDDP isn't better per say.
                            In my own car, I run GTX and ZDDP, just because I am old school and always have been partial to GTX (plus being a cheap at times and will buy in bulk when on sale, lol).
                            I'm in a quandry about oil right now. I too was using 20w50 GTX but found out about low ZDDP levels and that Castrol won't even publish their specs so switched to Valvoline VR-1 20w50. Now I find out that since it's a racing oil, there is no detergent in it and also isn't recommended for vehicles with a cat.
                            I'm thinking of adding the Rislone ZDDP and switching back to GTX, but what is the proper amount needed?
                            Or, what about Kendall GT-1? Supposedly has higher ZDDP rating-1600?
                            • ForcedFirebird
                              • Feb 2007
                              • 8300
                              The additive will say on the bottle, usually one bottle per 5qt. Just run Mobil1 15-50, it's cheaper than conventional and the additive. We have switched to M1 at the shop.
                              john@m20guru.com
                              Links:
                              • Sirotto
                                • 319
                                Just run the VR-1 or the GTX + Rislone or mobile 1. Your cat will be just fine as stated before. It has been seeing ZDDP for years on years now.
                                The now obsolete Kendall with the the old, I believe was SG rated, and have tons of ZDDP. The new SL rated is no where near what is used to be. When the EPA banished the SG rating the local parts stores could not sell it anymore so i went all over town and bought over 500 bottles for .15 each. That is teh only reason I still have some.
                                You guys should just listen to John (forcedfirebird). All the reading you can do on the interwebs will not compete with his hands on actual experience. Done.
                                "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery." - Winston Churchill
                                "People sleep peacefully in their beds at night only because rough men stand ready to do violence on their behalf" -George Orwell
