Let's see how much m20 heads suck.
  • digger
    • Nov 2005
    • 6181
    #31
    Originally posted by ForcedFirebird
    This is common procedure for flowing bare heads. When doing port research, the manifold will be attached as well as a throttle body minus the plate. The clay may vary 1cfm or so pending the shape, but when you lightly peel it off, it stays near it's original form.
    yeah i know it is but i I have never liked the fact that the opening to the head is not perpendicular to the centreline when flowing but it is when it is operating.
    • ForcedFirebird
      • Feb 2007
      • 8300
      #32
      Originally posted by digger
      you can work out the hp potential from the CFM, the stock head at 170cfm is about 260 bhp.
      Any increase from this adds to this proportionally to the potential. The key word is potential, the real hp will depend on:
      - how well the system as an overall system flows
      - what rpm the exhaust is tuned for (primary and secondary length and diameter)
      - camshaft events and profile
      - what rpm the intake is tuned for (intake runner length and diameter, plenum size)
      This is why the best heads are flowed as a unit with the intended manifolds on it.
      Potential is linear, the actual head flow is not.
      We can get in to exhaust, but would like to keep this thread about flow.
      We have flowed them in various configurations, can even flow with the actual exhaust on it, the bench was designed around this kind of testing. Sure, it's easy to say "this head flows xxxCFM: and when the intended manifold is bolted on, it drops, might even bring it back down to stock bare heads.
      In the past I have gotten a unit (heads/manis(s)) to flow more than a bare head.
      john@m20guru.com
      Links:
      • ForcedFirebird
        • Feb 2007
        • 8300
        #33
        We started messing with clay, adding material in places, changing the shape etc. The clay can be shaped in a way to gain ~6CFM.
        We are baking the carbon and blasting a manifold now to put on the head to keep the results stable. Hopefully we will have some results today.
        john@m20guru.com
        Links:
        • ForcedFirebird
          • Feb 2007
          • 8300
          #34
          Well. The eta, seta and 885 manifolds have been flow tested. The results are very surprising.
          john@m20guru.com
          Links:
          • future rs
            • Aug 2012
            • 514
            #35
            And....?
            • Balleristic31
              • Aug 2009
              • 4198
              #36
              Post results? :p
              -NICK
              • ForcedFirebird
                • Feb 2007
                • 8300
                #37
                eta manifold is better than you think. Let's start there.
                john@m20guru.com
                Links:
                • ForcedFirebird
                  • Feb 2007
                  • 8300
                  #38
                  john@m20guru.com
                  Links:
                  • ForcedFirebird
                    • Feb 2007
                    • 8300
                    #39
                    This is with the manifold attached, injectors installed, all vacuum lines blocked and throttle locked open. The non-test ports were also taped shut to prevent cross flow.
                    john@m20guru.com
                    Links:
                    • camip
                      • Nov 2011
                      • 1253
                      #40
                      From that chart the eta doeant look to good.
                      • TobyB
                        • 5286
                        #41
                        Really doesn't make you want to put a high- lift cam in there, tho, does it???
                        This is fun- thanks, John!
                        Ever since reading the Vizard (?) book where chapter 3 is all
                        about buying 3 shop- vacs and making your own flow bench, I've wanted to do it too...
                        t
                        • digger
                          • Nov 2005
                          • 6181
                          #42
                          very much an anticlimax
                          i think it is worse that i thought it would be
                          you go from being able to make 260bhp to 190bhp;) by fitting the ETA fanimold
                          now it is time to tell us some runner lengths and the diameter at various cross sections for the full picture
                          with the 885 and b25 manifold it would be nice to flow each runner to see any distribution differences
                          • ForcedFirebird
                            • Feb 2007
                            • 8300
                            #43
                            We are several tests in ;)
                            The variance between ports are negligible, extremely close to equal between castings and individual ports
                            john@m20guru.com
                            Links:
                            • ForcedFirebird
                              • Feb 2007
                              • 8300
                              #44
                              Also, Digger, those numbers are full "I", full sETA and full ETA. Didn't post our findings on mismatched parts.
                              john@m20guru.com
                              Links:
                              • u3b3rg33k
                                • Jan 2010
                                • 2452
                                #45
                                Mismatching notwithstanding, the comparison is moot. Why on earth would you do that to an engine that strives to be a turbo-free diesel?
                                Ich gehöre nicht zur Baader-Meinhof Gruppe
                                Originally posted by Top Gear
                                Just imagine waking up and remembering you're Mexican.
                                Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
