Swapped 325e to i no crank
  • delatlanta1281
    Dart Master
    • Mar 2006
    • 10317
    #31
    Did you switch the impulse sensor connector with the crank position sensor connector by the thermostat housing? Almost EVERY time something like this happens with an I engine install, this is the culprit. Even if you think you did it right, take 2 minutes and switch the two.
    Yours truly,
    Rich
    you kids get off my lawn.....
    • E30-325iS
      • Sep 2011
      • 191
      #32
      Originally posted by Jahman093
      coil pack is good
      wire from coil pack is good
      12v into distributor cap is good
      12v on rotor is good
      but I am not getting 12v when rotor passes over individual post inside cap.
      I assume that means its a bad cap?correct
      If you are getting 12Volts at the distributor cap you have a problem somewhere else, most likley the coil.
      • squidmaster
        • Aug 2011
        • 2666
        #33
        wait so now it cranks or?
        did you swap over the toothed crank pulley?
        • jo3y
          • Nov 2011
          • 80
          #34
          i would bet its your CPS
          MR2/Camaro Strut DIY
          http://www.3seriestech.com/viewforum.php?f=22
          • Jahman093
            • Sep 2012
            • 183
            #35
            squidmaster-yes it is cranking now. yes the toothed crank pulley was swapped over as well.
            jo3y- would a bad cps cause it not to start or have spark?
              #36
              A bad CPS will result in no spark.
              • Jahman093
                • Sep 2012
                • 183
                #37
                Do you happen to know the ohm range it should have?
                • Jahman093
                  • Sep 2012
                  • 183
                  #38
                  alright guys i am really stumped right now.
                  i have fuel but still no spark. i just changed the cps and still nothing. What else could cause no spark
                  • jo3y
                    • Nov 2011
                    • 80
                    #39
                    an improper air gap on your CPS, a bad coil, bad grounds.
                    off topic... i used to live in lakeland, small world
                    • Jahman093
                      • Sep 2012
                      • 183
                      #40
                      Grounds are good, replaced cps, and im getting 12v at coil. I am completely stumped :/
                      • jo3y
                        • Nov 2011
                        • 80
                        #41
                        what is the gap between your CPS and your trigger wheel. If that gap isnt correct the sensor cannot pick up the trigger wheel
                        • Alpine 7even
                          • Jul 2012
                          • 11
                          #42
                          Have you double checked that when the find tdc on the crank wheel, your cam gear is also at tdc? Timing is everything.
                          • BgEoEdR
                            • Jul 2009
                            • 3
                            #43
                            Did you try this? Its easy to get the two confused.
                            Sent from my DROID RAZR using Tapatalk 2
                            • Chriskbmx
                              • Apr 2012
                              • 972
                              #44
                              he is right. you need to check this out asap. before you throw anymore money into what could be an easy fix.
                              • Jahman093
                                • Sep 2012
                                • 183
                                #45
                                The gap between the cps and crank is .040. Before i put the engine in i replaced the timing belt and made sure both camshaft and crankshaft were at tdc. I have switched the two connectors.
                                I have been looking into checking the dme pins for power and continuity as seen in this thread http://forums.bimmerforums.com/forum....php?t=1487148
                                I checked everything that it said to do in this thread and it all checked out good.
