Swapped 325e to i no crank
  • Alpine 7even
    • Jul 2012
    • 11
    #46
    Originally posted by blueapplesoda
    did you plug in the 3 wire connector that comes off the old eta wire harness? its like black green and white or something like that, in a off-white 3-pin molex connector.
    Derek
    DedericMS
    Where does it plug into if you have an 89 I harness?
    • Jahman093
      • Sep 2012
      • 183
      #47
      Hey do any of you happen to have a picture of the wiring at the battery junction box thing on the passenger side? I am double checking all of my wiring and couldnt find a picture on google.
      • Jahman093
        • Sep 2012
        • 183
        #48
        Hey guys Im using my wires off of my eta engine and they dont have the cid sensor connected. Would this cause a no spark issue?
        • squidmaster
          • Aug 2011
          • 2666
          #49
          yeah you have to swap harness afaik
          • Jahman093
            • Sep 2012
            • 183
            #50
            Im not talking about the harness but the spark plug wires. For the 325i wires it comes with the cid sensor attached to the 6th wire and as of now i am using my spark plug wires off of my eta, which doesnt have the cid sensor coming off the 6th wire.
            • Gary Horneck
              • May 2011
              • 435
              #51
              You need the sensor wire from the i, or its a no go.
              2011 335i/1995 Mercedes C220 (rallyx)
              • squidmaster
                • Aug 2011
                • 2666
                #52
                oh yeah you need the plug wires as well
                  #53
                  The engine will run without that sensor, though performance and fuel economy will suffer.
                  • Jahman093
                    • Sep 2012
                    • 183
                    #54
                    Okay I hooked up my i wires and still no spark. Im getting 12v at coil and 12v through the coil wire but nothing after that. The cap and rotor are brand new. I have read about the fusible link in the trunk causing a no spark, but I get 12v on that wire where it hooks up at the battery junction box. Could that fuse still be blown and get 12v at the front? Is there anything the ecu needs to know to send a spark?
                      #55
                      The DME has to see timing data from a rotating engine to produce spark. You might have the CPS & Cylinder ID connectors swapped.
                      • Jahman093
                        • Sep 2012
                        • 183
                        #56
                        alright. I know Ive checked that but i will check again.
                        okay tried that still nothing.
                        • Jahman093
                          • Sep 2012
                          • 183
                          #57
                          bump
                            #58
                            For the engine to run the following conditions must be met:
                            Power on DME pins:
                            27 Start Input
                            18 Un-switched Power input
                            37 Power Input from Main Relay
                            Ground on DME pins 2, 14, 19, 24
                            Timing data from the CPS on DME pins 47 & 48 from a rotating engine
                            To have spark power must be present at the coil positive and ground pulses
                            from the DME's pin 1 must reach the coil negative. Power to the coil is
                            controlled by the ignition switch via C101. When checking for spark, use the
                            output lead from the coil to eliminate the distributor, rotor and plug wires.
                            To have injector firing power must be present at each injector and ground
                            pulses from the DME's pin 16 (Bank1) and pin 17 (Bank2) must reach the
                            respective injector bank. Note that the injectors are wired as two banks of
                            three. With cylinder 1,3,5 being bank 1 and 2,4,6 being bank 2. Power to the
                            injectors is controlled by the main relay. Injector firing is best checked
                            with a noid light.
                            The fuel pump relay must have power on pin 86 (relay coil) from the main relay
                            output (pin 87) and power on pin 30. The DME will ground pin 85 to turn on the
                            relay and power the pump(s) via pin 87. Of the above, only the fuel pump power
                            is fused. So if the there's power at pin 87, but not at the pump, check fuse
                            11.
                            The main relay and DME pin 18 receive power from the smaller of the two wires
                            that connect to the battery's positive terminal. That wire incorporates an
                            in-line fuse. When the DME is presented with a start signal, it grounds the
                            main relay pin 85 and furnishes power to the fuel pump relay, injectors, and
                            DME.
                            Troubleshooting:
                            Disconnect the battery and the DME cable. Then:
                            1) Disconnect the coil negative and check continuity from that connector to
                            DME pin 1. Also verify that from DME pin 1 to ground is an open circuit.
                            2) Check the resistance across DME 47 & 48, which should be 500-560 ohms. If
                            the CPS is dismounted, the resistance can be seen to change from about 500 to
                            540-560 ohms when a ferrous object is brought to the face of the
                            sensor. Neither pin should be grounded.
                            3) Check for continuity from DME 36 to main relay 85 and from DME 3 to fuel
                            pump relay 85.
                            Reconnect the coil, remount the CPS (air gap should be 1mm), plug the
                            relays back in, reconnect the DME, and connect the battery. Then do the
                            following checks:
                            1) With the key off, verify that power is present at DME pin 18 and main relay
                            86 & 30.
                            2) With the key on, verify that power is present at DME pin 27 and pin
                            18. Power to pin 18 is from the main relay and there should be power to the
                            injectors and fuel pump relay.
                            3) With the key on, verify that no voltage is present at the DME grounds (2,
                            14, 19, 24).
                            4) Verify that power is present at the coil positive and at fuel pump relay
                            pin 30. Those get switched power from the ignition switch via C101.
                            The engine will start and run (if poorly) with only those connections to the
                            DME in place. The other signals from Cylinder ID, AFM, temp sensor, etc., are
                            necessary for proper operation. But they won't prevent the engine from firing.
                            IMPORTANT:
                            A power check means seeing a voltage within about a tenth of a volt of what
                            you measure across the battery terminals, which should be at least 12.6v on a
                            charged battery.
                            A continuity check means seeing less that 1 ohm of resistance.
                            An open circuit means seeing a resistance of at least 100k ohms.
                            A good quality auto-ranging digital multimeter will make these tests much
                            easier.
                            • Jahman093
                              • Sep 2012
                              • 183
                              #59
                              pump relay 85.
                              following checks:
                              86 & 30.
                              14, 19, 24).
                              all this checks out.
                              DME pin 1.
                              this checks out as well except this part-(Also verify that from DME pin 1 to ground is an open circuit.)I do not get an open circuit reading from the multimeter. what could cause this?
                              • Jahman093
                                • Sep 2012
                                • 183
                                #60
                                anyone?
