Das Beast: My E30 track / street build
  • dvallis
    • Oct 2015
    • 1474
    #1756
    Rob had a good idea. The current version is fine for concept testing but ultimately we'd like a quick change splitter. Remove the two bumper bolts and pull the whole thing, bumper and all. I can do that using this complete aero front end and building an aluminum support frame inside it. That will be v2, once the new shop gets built. (Soon)
    "And then we broke the car. Again." Mark Donohue, "The Unfair Advantage"
    1987 E30 3L Turbo Stroker Das Beast
    2002 E39 M5
    • dvallis
      • Oct 2015
      • 1474
      #1757
      Time to fab the splitter tunnels
      CAD
      Fab with 16 gauge
      2002 E39 M5
      • dvallis
        • Oct 2015
        • 1474
        #1758
        WTF Was I Thinking?
        Lawn edging? Really? What in the actual fuck posessed me to use ugly ass LAWN EDGING for the splitter air damn? I mean, look at it! Did a pack of monkies do this?
        Lawn edging delete. Replaced with 2" aluminum angle.
        Frigging perfect. Ok, NOW I can move on to the dive planes and end plates.
        2002 E39 M5
        • Digitalwave
          is a poseur
          • 6300
          #1759
          You probably want to cover/close basically all the openings on the cow catcher, and those bumper cutouts too. There should be sufficient airflow to the radiator through just the grills. If you do end up needing to use the two large/center holes in the cow catcher for more air to the radiator, make sure the openings are ducted straight to the radiator, so the air can't bypass underneath or to the side.
          You will also want to re-install a hood seal and make sure the hood is tight up against it, so airflow through the radiator is properly exiting underneath the engine bay. You don't want the airflow exiting out the edges/back of the hood.
          RISING EDGE
          • dvallis
            • Oct 2015
            • 1474
            #1760
            Yeah, will be doing that. Intercooler and Rad need to breathe though : - ) The fog lights, vents under them and lowest vents on the center will get covered.
            2002 E39 M5
            • Digitalwave
              is a poseur
              • 6300
              #1761
              Oh yeah... almost forgot it was turbo!
              RISING EDGE
              • moatilliatta
                • 6158
                #1762
                Where will brake ducts go?
                I’ll be working on my duct work this upcoming month, then hopefully be building a splitter also.
                @Zakspeed_US
                • dvallis
                  • Oct 2015
                  • 1474
                  #1763
                  Could do brake ducts where the fog lights are, but not sure I need them with the big Hawk vented rotors. Will need to check next track day.
                  2002 E39 M5
                  • moatilliatta
                    • 6158
                    #1764
                    What do you think it’ll end up weighing?
                    Usually brake ducts aren’t an if, but when. And regionally different depending on tracks.. Some tracks are demanding on different parts of the car.
                    Those AFR’s look almost setup for e85, why richer at 11.5 AFR?
                    Do you wish you had to higher power band of the previous motor? Maybe cam timing could shift power up the RPM range? I wonder if something is choking up top.
                    Enjoying the progress :)
                    @Zakspeed_US
                    • dvallis
                      • Oct 2015
                      • 1474
                      #1765
                      Car weighs in at 3000 lbs with me and a half tank of gas. Just search the thread. That's NASA ST3. Power is tuned how we like it, comes on early with minimum lag. We're octane limited by the compression ratio on pump gas. Could easily push it to 400hp with more advance and race gas but that will reduce reliability, might not be as drivable and put us in a higher class. Will go with this until I can out drive the car LoL
                      2002 E39 M5
                      • dvallis
                        • Oct 2015
                        • 1474
                        #1766
                        Time for end plates and ramps.
                        CAD first
                        Transfer to aluminum. There are some weird cuts. I need a freaking notcher
                        nailed it
                        Clamps are your friend
                        End result is perfect
                        Rinse & repeat on the other side.
                        Final touch will be the aluminum front edging ... next
                        2002 E39 M5
                        • Digitalwave
                          is a poseur
                          • 6300
                          #1767
                          Looking good, although I don't think you want those end fences to go underneath the splitter itself. They are going to get trashed. Might want to go ahead and produce some duplicate parts or keep your paper templates for when you need to make a new one... haha.
                          When's it going back to the track?
                          RISING EDGE
                          • dvallis
                            • Oct 2015
                            • 1474
                            #1768
                            Back on the track soon as we finish this.
                            Side plates under the wing trap low pressue better. As to its service life .... I fully expect this thing to be violently ripped off the car. LoL
                            Splitter tunnel in place.
                            2002 E39 M5
                            • dvallis
                              • Oct 2015
                              • 1474
                              #1769
                              So here it is, to a first order done. Very light, feels functional. We'll see on the track.
                              Next time I'll take the whole damn thing apart and epoxy seal the plywood. Let it dry, few coat of black paint, then all back together.
                              I'm contemplating painting the aluminum bits, or not. Maybe black powder coat.
                              Prototype for the plywood edging. Next time.
                              2002 E39 M5
                              • dvallis
                                • Oct 2015
                                • 1474
                                #1770
                                Here's the grand finale for fab. Splitter edging worked out really well. Will counter sink all those screws at final assembly.
                                Aaaannnndddd ... that's it. Gotta say, this is one of my favorite fab projects lately. It's a really cool looking piece of work.
                                Now, take it all apart, epoxy seal the plywood, sand everything and paint. Probably basic black on the works. But that's for another day.
                                2002 E39 M5
