Das Beast: My E30 track / street build
  • moatilliatta
    • 6158
    #1741
    Are you building your own splitter tunnels?
    @Zakspeed_US
    • dvallis
      • Oct 2015
      • 1474
      #1742
      Yes. Going to fab them from 0.060" aluminum. We're out of sheet stock though. Metal shop opens Monday : - / Lowes only has 0.025" which is like tinfoil.
      "And then we broke the car. Again." Mark Donohue, "The Unfair Advantage"
      1987 E30 3L Turbo Stroker Das Beast
      2002 E39 M5
      • dvallis
        • Oct 2015
        • 1474
        #1743
        I like the overall shape so we're going with it
        At the proper height. Needs a 2" air dam. Will fab it from lawn edging or something
        This is bad. Splitter hitting oil pan
        3.7 degree up angle, i.e. lift generator. Definitely don't want that.
        Slight surgery to remove the offending piece
        Good clearance now
        0.28 down angle, same as garage floor
        Frame is starting to shape up like this. Not totally sure what the final product will be, but it's getting there
        There's room to make the tunnels 6" wider on each side. Would need different mounting points. I'm considering doing it.
        2002 E39 M5
        • Digitalwave
          is a poseur
          • 6300
          #1744
          Is the outer profile just roughed out for now or is it really going to be that large? It looks much too large for the wing you're running.
          Professional Awesome makes some preformed plastic splitter tunnels if you want to save some effort, they are relatively inexpensive.
          RISING EDGE
          • dvallis
            • Oct 2015
            • 1474
            #1745
            I started larger so we can cut it down as required. Might end up smaller. I'm still researching.
            Professional Awesome distributes Racebred splitters. They look fairly decorative. No tunnels or front supports from what I found. Anyway, I like building things : - )
            2002 E39 M5
            • dvallis
              • Oct 2015
              • 1474
              #1746
              These links are pretty good. Suggestions for splitter length follow each:
              NASA 4" -6"
              Professional Awesome 4" - 8"
              GRM 4" - 6"
              MOTOIQ ~4"
              Introduction to Aero 4" - 8"
              G-Stream < 3"
              So? As DigitalWave noted I have WAY too much splitter Probably only need ~4" to balance the 500 lb wing.
              Will get out the saws-all next time.
              2002 E39 M5
              • Digitalwave
                is a poseur
                • 6300
                #1747
                Here are the tunnels, $150 for the plastic regular size:
                Need more front-end grip to balance that big rear wing? Increase turn-in performance and high-speed stability with our track-proven front diffusers.
                RISING EDGE
                • dvallis
                  • Oct 2015
                  • 1474
                  #1748
                  OK, that's better. Too late for the saws-all so next time.
                  2002 E39 M5
                  • dvallis
                    • Oct 2015
                    • 1474
                    #1749
                    CFD : Cardboard Fluid Dynamics
                    This is a splitter tunnel
                    4 bends, it's done
                    2002 E39 M5
                    • dvallis
                      • Oct 2015
                      • 1474
                      #1750
                      Looking better. I like it. Will use this to study if I can make the tunnels bigger. Next time ....
                      2002 E39 M5
                      • dvallis
                        • Oct 2015
                        • 1474
                        #1751
                        New shape looks good
                        Tunnels fit
                        Frame mounts are good & strong
                        Pro tip. Level the car with driver weight in seat. #facepalm
                        Contemplating the mounting frame. I have lots of aluminum drop to work with
                        2002 E39 M5
                        • dvallis
                          • Oct 2015
                          • 1474
                          #1752
                          Adjustable height splitter frame mount.
                          U-Channel gets here from Dallas tomorrow so I can finish off the pivoting splitter attachment.
                          2002 E39 M5
                          • dvallis
                            • Oct 2015
                            • 1474
                            #1753
                            More fab. Simpler is better. I eliminated the height adjustment. Just using a straight mount to the splitter.
                            u-channel for the mounting point
                            Carriage bolts with washers to spread the load
                            After lots of bolting it on, measuring, taking it off, repeat. Coming together.
                            Mounts are really solid. Pivots to adjust the angle
                            Perfect fit
                            Now I have to design the rest of the mounting points, so down angle on the splitter doesn't become up angle and start generating lift. This will be harder as there is more crawling around under the car involved.
                            To be continued ...
                            2002 E39 M5
                            • dvallis
                              • Oct 2015
                              • 1474
                              #1754
                              Adjustable splitter supports. Whole thing is very sturdy. Valence next
                              2002 E39 M5
                              • dvallis
                                • Oct 2015
                                • 1474
                                #1755
                                Day off today. Created the air dam ... from lawn edging. Will block the lower valence holes with aluminum later
                                End plates and ramps are next.
                                2002 E39 M5
