Inconclusive compression test results
  • uturn
    • Dec 2010
    • 1004
    Rob dog pointed out the head bolts, you might have the stamped idle pulley that should be replaced also.
    • jeffnhiscars
      • Jun 2011
      • 6011
      Add the cam gear to this FYI. Both were recalled.
      Alice the Time Capsule
      • turbo55
        • Jul 2014
        • 223
        True, I think I'll replace the belt too then, thanks.
        Yeah those are the old bolts, this old girl hasn't had the head off in a longggg time (only once in like 91 if the service records are correct).
        Nah the cam sprocket is the right one. I also thought it was the stamped one the first time I saw it but when I did the timing belt and got a better look it's actually the newer cast one. I did have to change the oil drive sprocket though, that one was the stamped one. Weird that they were of different kinds.
        • turbo55
          • Jul 2014
          • 223
          Pulled the head, other than a ton of carbon deposits, doesn't look too bad in spite of 200k+ miles! still got cross-hatching!
          • digger
            • Nov 2005
            • 6153
            looks like oily deposits all over the place
