N/A aftermarket rods?
  • mr2peak
    • 2388
    Doesn't anyone make a set of rods for a natural aspirated M20? All I can find are 500g+ H Beams made for boost. S52's are 535g. Anything in the 450g range without shelling out for custom rods?
    I found titanium Pauter rods for ~$6090 a set.. that's not happening.
    Drive it hard. Maintain it well.
    A Topless Memorandum
  • digger
    • Nov 2005
    • 6198
    Molnar H-beams are just under 500g and great for clearances for the big cranks. cheap and good quality for the $$$.
    MM can sell ultra light I-beams but are 138mm and 21mm pin and like $1200 475g iirc
    pauter can do ultra light NA version of the rods but too much $$$
    to be honest i wouldnt worry too much about the mass, even OEM m50/s50 style rods are perfectly fine for lots of revs just get good bolts
    • varg
      Florida Turbo Man
      • May 2014
      • 3430
      No point unless it's a really high strung and heavily worked engine. You won't make enough power to hurt the stock ones, and there's no point in revving high enough for them to be a liability unless you're really going all out with a high dollar high compression cammed out build that will actually make more power beyond 7k.
      Video related
      And this build used M52B28 rods.
      IG @turbovarg
      '91 318is, M20 turbo
      • SkiFree
        • Jun 2011
        • 2766
        As you mention the 135mm S52 rods are 100grams lighter each vs the factory rods. The ebay/eagle/sp/ie rods are a bit lighter still as you mention, but I would stress that you'd still want to match them and them sized.
        As you have found there isn't a cost effective step beyond the point you are at.
        ADAMS Autosport
        • SkiFree
          • Jun 2011
          • 2766
          ADAMS Autosport
          • mr2peak
            • 2388
            I was looking at Molnars, as well as Arrow and Eagle. They all seem basically the same, IE as well. I was even thinking of getting 2 sets of Cxracing rods, using the best 6, and returning the rest.
            Rods have to be 135mm as I already have the Mahle/IE 2.9 pistons, so I can't cross-shop other lengths.
            Revs won't be very high. I'm looking at rods because S52 rods will need to be purchased and inspected, and possibly cleaned up as well. Might as well spend that on new rods that weigh less.
            • digger
              • Nov 2005
              • 6198
              Molnar are sized properly from what ive seen where as eagle/CX and other ultra cheap ones not so much. Arrow are extremely expensive and sounds like a total waste for your application. you're better of spending money on things that matter alot more.
              the other ones ive seen that look good are the I-beam from integrated engineering
              At IE, we are hell-bent on making the VW / Audi cars we love better. Our mission is to engineer hardware and software upgrades that out-perform original equipment in speed and strength. IE parts are second to none because we design them the way we want them for our own cars. We share your passion for making your...
              • TobyB
                • 5296
                then you should be ok with almost anything.
                Rods just don't fail in compression.
                It's the off- throttle at 8250 that pulls the caps off them...
                There are some gains to be had in rods, but they're tiny- BMW knew their shit
                when they made these engines...
                t
                • varg
                  Florida Turbo Man
                  • May 2014
                  • 3430
                  ^finally someone else here is picking up what I'm putting down.
                  IG @turbovarg
                  • mr2peak
                    • 2388
                    Oh no, I get it. I know I won't be getting a bunch of HP from rods, that's not the point. The engine is a 85/84mm 2.9 M20 with the IE/Mahle pistons, ARP studs, mild porting, 272 cam, supertech valves, HD rockers, new springs, retainers and rocker shafts. RHD ITB's, IE long tubes, custom mid pipe to Stromung catback with MS2 to tune. 323i flywheel to keep it nice and street-able. Rev limit at 7,500 but I doubt it will make power that high up. I would like to use the nitrous controller to run a 2 stage 50/50 shot to get ~300 to the wheels for the drags. Admittedly 300whp easily handled by any of the rods available.
                    But this is not a "budget" build, nor a "race" build. It's a middle-ground street build with longevity in mind. Stock rods lack rifle drilling; adding oil squirters to make up for this is not always the best thing, and will cost more money. Used S52 rods might have to be re-machined to fit. Again, that will cost more. Might as well use the money to get something better to begin with; a few hundred more spent wisely won't ruin this project.
                    I sent an email to Integrated Engineering, they seem like a great middle-ground between the budget options and the "more than I want to spend" collection.
                    Molnar's seem to be the lightest option within budget. No rifling but that's not a deal-breaker, most M20 rods do fine without.
                    Way above and beyond my comfort level. Seems that I was looking at single rod prices, not the set of 6.
                    • TobyB
                      • 5296
                      Nitrous is not, in my book, n/a anymore.
                      So yeah, maybe you need more, since 7500
                      seems to be the outer limit for stock rods.
                      I'd say with 50 you'd probably still be ok,
                      but saying 'I'll keep it to 50'
                      is like saying 'I'll only ever go to 1/2 bar' with a turbo...
                      t
                      • mr2peak
                        • 2388
                        I will keep it low. I have a very clear goal with this car, and high nitrous is definitely not on the list. Turbo would be a way better choice if this was the case.
                        Anyone have input on the value of rifle drilling?
                        • varg
                          Florida Turbo Man
                          • May 2014
                          • 3430
                          Nice to have but E30s run endurance races without them and have no trouble...
                          IG @turbovarg
                          • digger
                            • Nov 2005
                            • 6198
                            its not required for what you are doing, nothing wrong with it but probably youre paying extra for it...
                            • ForcedFirebird
                              • Feb 2007
                              • 8300
                              I have personally built many m20's, one having almost identical specs. No, you won't be making any power at 7500rpm - definitely not with that cam it's too small - I would suggest the new IE grind. 300 to the wheels don't need rods, anyways. Digger made a good suggestion with the 24v rods. They are lighter and about the same strength. Stock rods have shown me that 350+whp is a non issue, m20 or 24v. Spend your money on machining. Weight match everything, balance, deck, align bore, high speed balance assy, and recon rods.
                              Make sure you head porter knows what he is doing, or you run a good chance of gaining nothing or more likely, hurting flow. Don't even touch them without a flow bench. We flowed many "ported" heads.
                              john@m20guru.com
                              Links:
