Adding a knock sensor
  • berlow94
    • Jan 2013
    • 1063
    Anyone here have experience with adding a knock sensor (or two) to an M20?
    Going to a standlone ECU and would like to have it Knock limited (closed loop knock control) for safeness.
    I'm assuming you would have to figure out an appropriate mounting boss and then have everything acoustically tuned for the bore size and spacing.
    The best one-stop shopping for German car parts and lifestyle: http://www.gutenparts.com/
  • nomansland92
    • 1657
    I run active knock control on my m20 with haltech
    Here's how I mounted it to the side of the block
    To set it up just did the math for the knock frequency for now and set the dB rating above natural engine noice, next time on the dyno if I have time I'm going to run into light knock on purpose and verify the settings and adjust if needed.
    But so far it works great and Is a great safety feature.
    Sent from my SAMSUNG-SM-G891A using Tapatalk
    IX being restored here
    Ix turbo build here
    • mr2peak
      • 2388
      Anyone add a knock sensor with megasquirt?
      Drive it hard. Maintain it well.
      A Topless Memorandum
      • berlow94
        • Jan 2013
        • 1063
        I don't think MS actually has well functioning knock control or the ability to knock limit a motor.
        • mr2peak
          • 2388
          This kit here: http://www.viatrack.ca
          It is recommended in the MegaManual, but the MegaManual also says it's for "Experimental purposes". Everything else I've read says that it works quite well.
          Relevant MegaManual link http://www.megamanual.com/ms2/knock.htm
          • downforce22
            • Aug 2009
            • 3192
            I want to add a knock sensor also, curiously following this thread
            • TobyB
              • 5265
              knock sensors are more for tow vehicles than race cars
              says David Redszus on a different forum... cracked me right up.
              t
              • berlow94
                • Jan 2013
                • 1063
                t
                Ya that sounds like somebody stuck using 30+ year old engine managment. Does he know what "knock-limited" means?
                • downforce22
                  • Aug 2009
                  • 3192
                  Anybody get their installed yet?
                  • ForcedFirebird
                    • Feb 2007
                    • 8300
                    I have found an n/a m20 stops making power well before it knocks (using the angular squish pistons/head anyways), but the coolant drain hole on the passenger side of the block would be a great place for one. The flat pistons and 200/731 head may be a different story, though.
                    john@m20guru.com
                    Links:
                    • Coyote_ar
                      • Sep 2009
                      • 175
                      what i've read, is that the M20 makes so many noises from its valvetrain, that the knock sensor tends to pick them as knocking when its not really happening. and if you lower the sensitivity of the sensor to avoid false positives, then you wont detect knocking when you can tell its happening (on the dyno).
                      again, this is not first hand experience.
                      ---E30 320i Hennarot 1984 Sedan---
                      • digger
                        • Nov 2005
                        • 6146
                        by all reports Rama has had great results with flat tops and the 200/731 heads, it would have the same knock suppression capabilities as the 885 with the OEM style slugs. of course this is assuming you set the engine up correctly with suitable static CR , cam timing, piston to head clearances and a proper tune etc
                        on the other hand ive got couple mates with generic slugs with 885 and they are knock limited quite a bit it seems
                        • ForcedFirebird
                          • Feb 2007
                          • 8300
                          That's odd about the slugs. We tuned an eta with an 885 head for Time Trials in 2 different configurations so that a simple ECU swap and ballast, it could compete in two classes the same weekend - it got a track record in both classes and the two drivers won a full set of Hoosier's as a result. Anyways, the car made the most power with 27°, and the de-tune was in the low 20's (23° IIRC)
                          In contrast ITB 2.8 we built was left at 30.6° max, it was losing power with anything over 32.
                          Either way timing in the 30's *shouldn't* cause knock on an m20 so long as fueling is good. For fun we ran one up to 45 just to see if there was anything audible, but there was none, nor any evidence on the plugs it was just a dog with that much timing. Many times we dyno a stock m20 with stock electronics and they are in the 14 AFR's at WOT (but find mid-13's to be the "sweet spot), they are fairly robust over all, and pretty "detonation resistant" as they were designed.
                          john@m20guru.com
                          Links:
                            • 34839
                            An NA M20 isnt likely to be knock limited before MBT anyway. I honestly think you are overcomplicating things..
                            Edit: ForcedFirebird beat me to it and he has even more M20 experience than me. Knock control is a waste of time on an NA M20. My personal engine reached MBT long before the knock threshold.
                            • tschultz
                              • Jun 2013
                              • 332
                              I have read about this one in a few places and a few people use it. Seems like a smart addition if you are trying to develop a good safe tune...
                              So then how does one fine tune timing if one has no idea if knock is occurring? By the time you hear it, isn't it already too late?
                              http://www.Drive4Corners.com
