ForcedFirebird's m20 dyno thread.
This is a sticky topic.
  • ForcedFirebird
    • Feb 2007
    • 8300
    #31
    Same car as post #3 and #23, but added a lightened/balanced/blueprinted 2.8 rotating assembly (has heavy 130mm m20 rods at 550gms), 2mm shaved block, 9.5:1 compression. We played with the runner lengths on the ITB's and got a ma peak of 217/202, but it was so peaky. This was the settled tune and runner length (most area under the curve).
    Overlay from when we met the car to current status. Trying to talk him into a larger cam. Even though the compression is 9.5:1, the RHD ITB's are great at cylinder filling and believe a larger cam would help this one out...
Name:	28itbm20 before and after.jpg
    john@m20guru.com
    Links:
    • Stephen
      Шлем ишака
      • 10774
      #32
      Originally posted by ForcedFirebird
      Updated post #2
      Sorry, missed your post until editing post 2. If you notice, they are kinda in an order from stock-ish to built, so bear with me. I have not had a local 3.x built m20 to put on the dyno yet. Have a budget stroker using the eta crank/rods, -2mm block, B&B to .1gm, stock-ish head with just my flow tested valve job, and 272 cam that will be coming back for the tune once it's broken in a bit, but logistics has been keeping it delayed as he is over a half day drive from the shop. I also lost in the neighborhood of 20 cars when the dyno pc tower crashed - the same reason I now cloud them shortly after. :/
      Interested to see what that puts down!
      • 2mAn
        SeƱior Mod
        • 20705
        #33
        updates!?
        Simon
        Current Cars:
        -1966 Lotus Elan
        -1986 German Car
        -2006 Volkswagen Jetta TDI
        Make R3V Great Again -2020
        • ForcedFirebird
          • Feb 2007
          • 8300
          #34
          Building another one now that will surely go to the dyno as it's getting installed in the race car and will need plots for HP/WT ratio for classing.
          Originally posted by 2mAn
          updates!?
          None lately. Have an s50 rebuild in the works, and it's racing season so we will be going to the rollers soon.
          john@m20guru.com
          Links:
          • jeffnhiscars
            • Jun 2011
            • 6010
            #35
            John clear your inbox :)
            Alice the Time Capsule
            • ForcedFirebird
              • Feb 2007
              • 8300
              #36
              Email is valid in signature. Barely sit at PC anymore, even cell phone sits in office. This is racing season in FL....
              john@m20guru.com
              Links:
              • ForcedFirebird
                • Feb 2007
                • 8300
                #37
                Did two "budget stroker" 2.7's today on the dynojet. Will post results and anecdotes later, but 2.7 crank/rods with b25 pistons and milled deck is super viable, even with the reduction in cam timing.
                2 examples today. One made at the wheels: 180hp/179tq and the other did 168hp/172tq
                Stock used blocks/pistons, fresh rings/bearings, a bbtb, headers, and even aftermarket ECU was involved. Lol
                john@m20guru.com
                Links:
                • Reichart12
                  • Aug 2012
                  • 2161
                  #38
                  Wow those numbers are fantastic for a 2.7 stroker. That's promising data for anyone thinking about going that route.
                  Instagram: Reichart12
                  • ForcedFirebird
                    • Feb 2007
                    • 8300
                    #39
                    These are NOT 2.7 short blocks with a 885 heads. They are 81mm cranks, 130mm rods, stock b25 pistons and machine the block deck to get compression height back. We took .080" off these blocks, but beware of squish. Both engines got shaved heads, one was too close at .035" piston to head clearance. To be safe without measuring, I would suggest taking .070-.075" if you want to use an off the shelf head gasket.
                    john@m20guru.com
                    Links:
                    • redlightpete
                      • Mar 2012
                      • 264
                      #40
                      Did these both have stock cams and non-adjustable cam gears?
                      • Reichart12
                        • Aug 2012
                        • 2161
                        #41
                        Ahh thanks for the clarification. I must have missed that if you mentioned it before. Still good power output.
                        • LowR3V'in
                          • 4209
                          #42
                          have you seen any power from retarding the cam seeing as allot of people resurfaced/shaved heads but with no adjustable gear.
                          • ForcedFirebird
                            • Feb 2007
                            • 8300
                            #43
                            Honestly I have not done much with the adjustable gears on the dyno.
                            Here's the graphs from Sat.
                            81mm crank, 130mm rods, b25 pistons, .080" (2.03mm) off the deck, stock cam (and cam gear), in house rebuilt head, .035 quench, bored throttle body, extrude manifold, eBay headers, single 2.5" exhaust through 2 mufflers. MS1 with a smooth elbow pipe, cone filter.
                            81mm crank, 130mm rods, b25 pistons, .080" (2.03mm) off the deck, IE 272 cam (stock cam gear), in house rebuilt head, .050" quench, stock intake/TB, stock exhaust manifolds, single 2.5" exhaust with a single resonator. Stock ECU re-mapped at the dyno.
                            I believe this car "should" have made more power, was actually a little disappointed. Later after watching a video sent by a friend, I can hear a lot of diff noise that was impossible for me to hear in the car while tuning (one car bay with a dyno in it). Doubt we will bring it back to the dyno, just rebuild the diff and send it racing.
Name:	22 endurance car.jpg
                            john@m20guru.com
                            Links:
                            • jeffnhiscars
                              • Jun 2011
                              • 6010
                              #44
                              Could the extruded intake have made that much difference and if I may ask what that costs ?
                              • digger
                                • Nov 2005
                                • 6117
                                #45
                                It's amazing that both graphs are basically identical upto 5000rpm.
                                So the first has
                                - standalone ecu
                                - header
                                - exrtrude hone
                                - bbtb and fine style inlet
                                - tighter squish clearance
                                But the second has a IE 272, is it regrind or Schrick knock off ?
