ForcedFirebird's m20 dyno thread.
one tensioner on the timing belt is more than enough....89 E30 325is Lachs Silber - currently M20B31, M20B33 in the works, stroked to the hilt...
Originally posted by digger View Postone tensioner on the timing belt is more than enough....
yes there is only one but i'm against incorporating additional idlers, tensioners into the Vee belt system for the additional cost, points of failure and maintenance.
it would make more sense on an M30 which needs the extra space89 E30 325is Lachs Silber - currently M20B31, M20B33 in the works, stroked to the hilt...
Originally posted by digger View Postyes there is only one but i'm against incorporating additional idlers, tensioners into the Vee belt system for the additional cost, points of failure and maintenance.
Originally posted by digger View Postit would make more sense on an M30 which needs the extra space
(ignore the alternator holding up the SC, that was just to hold it while checking the SC > plenum > throttles alignment)
Originally posted by ForcedFirebird View PostOnly options ATM are using a 24v damper, which is larger in diameter and has the OlT mark at 2 o'clock vs 10 o'clock (easy fix), will require custom CPS bracket and either change to vee belt damper, or serpentine alternator other oprtion is totally a custom /adapted unit.
Das Beast 2.8L turbo stroker M20
See Build Thread page 1 for specs
BLACK : 6 psi
RED : 10 psi
BLUE: 16 psi
GREEN: 19 psi
"And then we broke the car. Again." Mark Donohue, "The Unfair Advantage"
1987 E30 3L Turbo Stroker Das Beast
2002 E39 M5
It's really well behaved, drivable and fun. I'm getting 5-10 psi boost at partial throttle, so maybe 200-250 HP. At WOT 19 psi the boost comes on like Mike Tyson punching you in the face. Make sure you're pointed in a straight line, hold on and try not to scream like a little girl. :-)"And then we broke the car. Again." Mark Donohue, "The Unfair Advantage"
2002 E39 M5
Thanks for that, dvallis. It is very rare that someone posts a dyno printout that good. Usually it's one or two runs just to brag about the peak hp number when the comparison is the real value of a dyno in the first place. I had a little fun with your numbers since I don't get to see this kind of comparison with turbo cars too often. Of course it's not gospel, just for comparison, and forcing linearity is only way to easily display what kind of power increase your build is seeing per added psi of boost (the slope of the line).
IG @turbovarg
'91 318is, M20 turbo
[CoTM: 4-18]
'94 525iT slicktop, M50B30 + S362SX-E, 600WHP DD or bust - updated 3-17
This thread is great. Thanks to everyone who's contributed. After reading through it, I'm amazed that my engine (284/272) on a stock b25 has held up d/t my severe lack of knowledge with tolerances/clearances. Round 2 is going to be much better.
How many miles should a Schrick 284/272 cam last? I think I'm around 40k, regular oil changes Castrol GTX 20/50
09 BMW 328xi touring 6spd
05 Subaru Outback XT 5spd
87 BMW 325is
a few bicycles
- Likes 1
Originally posted by LowR3V'in View Posthave you seen any power from retarding the cam seeing as allot of people resurfaced/shaved heads but with no adjustable gear.
Figured I'd add to this thread- two 3L M20 cars built by Zionsville Autosport went on a local Dynojet today.
Both M20b30s were built using M54b30 internals, pistons shaved down 2mm and then had .0017 of ceramic coating added to the domes. Using a thicker MLS (not totally sure of exact size), compression is supposedly around 12:1. These aren't my claims, just the info I got from Dwight.
Car one was stock ecu, car two was Megasquirt. Stock ECU car had a 272 cam and a BBTB, but made less power than the car with Megasquirt.
Dwight and I had a bet on what the Megasquirt car would make, I guessed 185/210.
Anyway, onto the results. Also, to note, I tried to do an overlay in WinPep but couldn't get it to read right. I have the dyno files that I can send someone if they cared to do an overlay of cars 1&2.
Car #1:
Runs 1&2 are with stock chip in the stock ECU, runs 3&4 are with an SSSquid chip setup for this configuration of parts. You can see the curve smoothes out and AFRs also get much safer with the squid chip where the stock ECU was going lean.
Bolt ons:
-IE Billet 272 Cam
-BBTB
MILLS by Bobbie Morrone, on Flickr
Car #2:
This car has a PNP Megasquirt setup with a Miller MAF somehow configured in there. I don't know the details of the t00n, but the bottom end is the exact same as car #1.
This car has a stock cam, and otherwise doesn't have any mods outside of the standalone, but made much stronger numbers. The tune is crazy rich up until 5K, and falls off like crazy after 6K.
LILE by Bobbie Morrone, on Flickr
Edit: Adding a photo of car #1 because it's a beautiful, extremely low mile Japanese MT2 car.
Untitled by Bobbie Morrone, on FlickrLast edited by AWDBOB; 03-22-2021, 07:13 PM.
- Likes 1
